Old 06-03-2021, 01:05 PM #1
Toystory2's Avatar
Toystory2 Toystory2 is offline
Toystory2 is on a distinguished road
Toystory2's Avatar
2007 4WD - Worth it?
Hi,
Long-time Tacoma owner, looking at a 4th Gen 4Runner to get a little more room for the kids.
In particular, I am looking at a 2007 4WD with 159k miles on it.
No known issues, except for a tire pressure light on the dash. Most maintenance records have been kept. Looks like the usual has been done: oil changes, plugs, tires, fan belt, and brakes. There is some surface rust underneath, but most of it has been undercoated (not sure what that means).
It has some mods, including Apple Car play and remote start. It is also pre-wired for an amp. Are there any concerns with this wiring work that's been done?
He is asking $13,500 but I will try to negotiate that down to around 12 or so.
Since I am new to this, how risky is this to buy? Are there certain things I should check when I go see it in person?
I would greatly appreciate any advice one could offer!
Toystory2 is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 01:25 PM #2
southern_runner southern_runner is offline
southern_runner is on a distinguished road
There are lots of guys on here with more knowledge than me, but you would likely need to do the timing belt if it's a V8...V6 has the chain. I think some of the 4th gens had an issue with the exhaust manifold cracking (again on the V8). V6's can have head gasket issues, but I think in 2007 they had that issue sorted out.
Hopefully some others can chime in and tell you what to look for.
southern_runner is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 01:35 PM #3
Toystory2's Avatar
Toystory2's Avatar
Thank you. I have read about some of that as well. Wondering if there might be anything else? I know making sure the 4WD is operational is a definite thing to check.
Old 06-03-2021, 01:58 PM #4
3bears 3bears is offline
Real Name: 3 Bears
3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light
Real Name: 3 Bears
I recently did tons of research on these...and just missed out on buying one. Anyway....records are good to have...2007 is past the year of potential head gasket problems. Tire pressure light is common I guess and there is a simple write up to turn it off and bypass it. Exhaust headers can be an issue in the v6 as well but not as common.
Like all yotas....rust can be an issue so look at it very good.
2000 SR-5 Highlander. 4:30's, factory locker green bought 6/21
2000 SR-5 V6 Auto . lifted, e locker, other cool stuff, totaled 10/20
Old 06-03-2021, 02:10 PM #5
joec500 joec500 is offline
joec500 is on a distinguished road
I just purchased my V8 2006 limited out here in the SoCal with 144k miles for 13,900 I found this to be the lowest price of ANY v8 4x4 in 400 mile radius. I jumped on it the next morning. These vehicles are getting so expensive over the last year.
joec500 is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 02:10 PM #6
Keros Keros is offline
Keros will become famous soon enough Keros will become famous soon enough
Was it undercoated brand new?
If it was undercoated at any other time than when it just came off the mobile parking lot, then the undercoating can multiply rust.
Get under there and give the frame a wack with a hammer. It should ping and ting like hitting a steel plate. A dull thud means you're hitting rust. If anything flakes off or dislodges from the frame while getting smacked with a hammer, you've done yourself and the owner a favour by discovering there's no real metal under that undercoating.
Don't beat the hell outta it though, you're not trying to put dents in it. Just a good little whack to make sure she's solid as a rock... or steel plate, in this case.
I've seen undercoating that looks great but then comes off in giant chunks with rust holes underneath... suddenly I can see the pedals in the driver's foot well... And the only thing that was between it was some rubber coating and carpet. (not on 4Runners though)
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 02:28 PM #7
Toystory2's Avatar
Toystory2's Avatar
Thanks for the advice, I'll see if I can find out when the undercoating was done.
I have some pics of the underneath. I'm not the best at assessing this stuff, unless it's real bad and falling apart LOL
2007 4WD - Worth it?-194729355_4303885199644364_4313870865409836966_n-jpg
Old 06-03-2021, 03:25 PM #8
Yeah, it's impossible to know from a picture for the trouble spots.
Regardless, 60% of the problem starts inside the frame rail where no one can see it anyway... Then one day a hole shows up.
That's the trouble with the rubberized undercoating, its textured look hides the rust really well to visual inspection. In any case, once it's applied to a surface, eventually water infiltrates behind it in spots and starts to collect in the void, keeping the metal wet, accelerating the corrosion process. In perfect world it would have flawless adhesion, where nothing can get between it and the metal... but alas, 'tis not this world.
You could/should get an inspection done at a reputable shop. Those are one of the many things they should be looking at.
Best luck
2005 V8 Limited
Old 06-03-2021, 04:45 PM #9
Toystory2's Avatar
Toystory2's Avatar
I've seen some 4th Gens at dealerships going for over $20k, but I think there were under 100k miles. Still that's crazy!
Old 06-03-2021, 09:43 PM #10
Toystory2's Avatar
Toystory2's Avatar
I canít confirm if the tranny or diff fluid has ever been changed. Are we still in the safe zone to change it at 160k?
Old 06-03-2021, 11:17 PM #11
montijo505's Avatar
montijo505's Avatar
I just changed my tranny fluid at about 150k. No problems but I did the radiator line drain and fill, thereís a write up on the forum. Only thing you absolutely do not want to do is a pressurized flush. Diff should be fine unless itís making noise.
$13 , 4wd , 500 , wiring , work
Looking at a '16 TRD Pro, worth it? joshik 5th gen T4Rs 12 09-13-2020 10:42 PM
Are they worth the $$$ 0verland 4th Gen T4Rs 10 10-01-2017 10:45 AM
Worth it? ChellaBella Off Topic 3 01-24-2013 11:02 PM
2007 Sequoia - 2007 Toyota 4Runner kraftwerkauto 4th Gen T4Rs 4 08-23-2012 04:35 PM
is this 3rd gen worth it? peytonracer4 3rd gen T4Rs 8 11-30-2011 08:50 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
