06-04-2021, 07:57 AM
07 Alternator advice
Last night the battery light came on. After testing at the battery while running i am only getting 12V. After watching youtube looks like a easy swap out. Anyone have advice on a good inexpensive replacement? Also any additional tips i should be aware of?
Thanks in advance.
06-04-2021, 09:56 AM
I picked up a reman alternator from Advance Auto parts a couple years ago and its been working great. I found a coupon online so I got 20% off
Shootersanks
-2007 Shadow Mica SE 4Runner
06-04-2021, 10:52 AM
Check your battery ground cable. If its corroded, it can also affect the voltage.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
06-04-2021, 11:57 AM
Rockauto.com get a denso unit
06-04-2021, 12:03 PM
Pretty simple following the Factory Service Manual pages. Two banana job with basic tools.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
06-04-2021, 02:39 PM
This- I was having voltage fluctuation issues at idle due to poor cable connections.
'08 Silver SR5 V6 4x4: OEM+
06-04-2021, 02:48 PM
Thanks all I am getting a solid 12V at all rmp's
06-04-2021, 04:13 PM
Had my mechanic do mine it was not a small job
Had my alternator replaced on my 06/ 07 last year looked like a straight forward job but my guy ended up having to disconnect the AC system which required draining and filling in order to get the old one out.
06-04-2021, 05:03 PM
Sorry but you got taken. The alternator in the V6 and V8 can be taken out and re-installed without removing the A/C line and a recharge.
06-04-2021, 05:07 PM
From the manual, V6.
06-04-2021, 05:08 PM
Pretty straight forward swap, at least on a v6. I went with a low mileage used OEM unit. These seem to last longer than a rebuilt from your local parts guys.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
06-04-2021, 06:21 PM
I bought a used unit from a dismantled 4runner. $65 worked like a charm. OEM is always better than aftermarket or rebuilt.
06-04-2021, 08:32 PM
Randy, you're looking in the wrong manual. The v6 is a 1GR FE engine.
06-06-2021, 08:44 PM
Real Name: Elliott
Real Name: Elliott
Originally Posted by gimlithepirate
Followed a similar route: went 240a and did the big 3 upgrade. Had it for over a year, works well.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
