Old 06-08-2021, 09:43 AM #1
alaskaman's Avatar
alaskaman alaskaman is offline
alaskaman is on a distinguished road
alaskaman's Avatar
Wet Carpets
I noticed both front carpets were wet. Did I leave the sunroof open....? Did it leak? Left the car running with floor heat for a few hours seemed to do it. Then this morning driver side only slightly wet again. Car cover was ON past two days....having the sunroof drains inspected today. I went up there and water was pooled.
It may need to be replaced as the odor is present.
Suggestions on any of it?
2007' V6 SE 4WD PIAA 520's.
Yakima Load Warrior
Michelin LTX M/S 265 65 17
Westin Bull Bar Weathertech Mats
Bilsteins 5100's
alaskaman is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 10:12 AM #2
Humble Leader's Avatar
did you recently replace your windshield by any chance? it could be the sunroof drains, are there any signs of wetness on the headliner. it would be a strange coincidence if both drains got clogged at the same time, did you park under a tree with the sunroof opened
Old 06-08-2021, 10:36 AM #3
alaskaman's Avatar
alaskaman's Avatar
No to both. I am however having the windshield replaced due to long existing cracks and they are going to test the drains.
Yakima Load Warrior
Bilsteins 5100's
Old 06-08-2021, 05:57 PM #4
puchitotrd puchitotrd is offline
puchitotrd is on a distinguished road
I also have water coming from under fusebox , did you find a solution?
puchitotrd is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 07:47 PM #5
hectorh hectorh is offline
hectorh is on a distinguished road
I had the same issue. I tracked it down to a plugged sunroof drain. The sunroof overflowed, dripped along the drain pipe and landed in the footwell, behind the fuse box.
The sunroof drains are one at each front corner of the sunroof, just where the wind breaker lowers into when the sunroof is closed. The holes are about 1/4" in diameter, very easy to clog.
Nightmare to fix ... had to remove the carpet and get it cleaned as it has a waterproof layer that prevents from getting at the moisture under the carpet.
It's a big job. Take out all the seats, center console, bottom half of the dash, A and B pillar covers.
While I had the carpet out, I also noticed the sound proofing tar had all cracked and separated from the chassis, so I had to replace all that too. I have some pictures if anybody is interested.
Good luck!
hectorh is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 08:34 AM #6
alaskaman's Avatar
alaskaman's Avatar
I had the windshield replace cracked for years and ran a weed eater string down both front tubes until the ran well with pressure water I hope that solves the issue. I’m going to pull drivers side carpet to make sure no mold. Got a nice car cover for the Beast as PNW tree powder I think was part of the problem. If no mold. Will have the carpets professionally cleaned and dried. I recently got a new DD Lexus 350 ES so after 14 years of travels I’m going through the results of those years from Alaska to Mexico and my Beast in ship shape. Still my best vehicle.
Yakima Load Warrior
Bilsteins 5100's
Old 06-10-2021, 09:29 AM #7
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
Also make sure the drain tube goes all the way down into the rocker panel. On one of my vehicles, the tube had shrunk in length enough that it was draining inside the footwell instead of all the way down into the rocker panel.
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 12:34 PM #8
alaskaman's Avatar
alaskaman's Avatar
Thanks for these replies...appreciated.
Yakima Load Warrior
Bilsteins 5100's
car , carpets , odor , sunroof , wet
Want a new carpet? 50% Off! OC Auto Carpets. Scramble 3rd gen T4Rs 3 11-27-2016 11:52 AM
WTB stone grey carpets for 2003 Sport steuny For Sale: T4R Items 1 03-04-2013 02:31 AM
Carpets cleaned 2000runr 3rd gen T4Rs 5 05-21-2010 09:14 PM
Looking for OEM Carpets Michaelt 3rd gen T4Rs 4 06-15-2008 05:12 PM
Flooded carpets - best way to dry them. tomzapf Off-Roading 9 08-26-2007 12:08 AM
