Old 06-08-2021, 08:59 PM #1
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Smile Need part numbers for ATF hoses in and out of radiator v6 4G T4R 2008
Does anyone have these part numbers? Just the rubber hoses from the hard lines to the radiator.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 08:15 AM #2
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Just buy Gates 3/8” trans hose from auto parts store. If you get lucky, you can find Gates hose on ebay in bulk.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 10:14 AM #3
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
PartSouq Auto Parts Around the World
Plug in your vin, profit.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 10:15 AM #4
Piggity Piggity is offline
Piggity will become famous soon enough
This is what I did with my ATF cooler install. My power steering and ATF cooler hard lines were rusted out and leaking, so I figured it was a good time to add an ATF cooler and just replace the rusted lines with ATF rubber lines. At the same time I bypassed the radiator cooler and just went straight from the transmission to the ATF cooler.
And I used 3/8" lines from a parts store, the rubber lines were rated for power steering or ATF.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 10:30 AM #5
I thought in cold climates it was best to run additional trans coolers in series after the radiator cooler to help the ATF get up to temp more quickly, and remain in the range of operating temps by exchanging some heat from the coolant/rest of the radiator?
Old 06-09-2021, 11:23 AM #6
That's the theory I guess. I don't really do much driving in the winter so I figure if the most driving I do is in the summer when I tow a heavy TT then I need the extra cooling. If I were to do it the right way I'd use a thermostat in the ATF cooling circuit so when the transmission is cold it wouldn't flow thru the cooler but I'm pretty cheap.
Old 06-09-2021, 02:21 PM #7
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Inlet hose - 32941-60280
Outlet hose - 32942-60390
techno is offline   Reply With QuoteReply With Quote
hoses , lines , numbers , part , radiator
Radiator hoses lifespan nathannookie General Discussions 3 05-19-2020 05:59 AM
Replacing radiator - other hoses etc. Ghostrider 3rd gen T4Rs 5 12-13-2019 08:34 PM
Radiator hoses? atalarico 3rd gen T4Rs 7 07-01-2016 09:59 PM
Upper/Lower radiator hoses same part#? Monkeybutt2000 3rd gen T4Rs 4 08-10-2013 04:17 PM
sucked up radiator hoses. 3G_runner 3rd gen T4Rs 5 01-13-2010 11:12 PM
