Old 06-12-2021, 04:50 AM #16
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Originally Posted by Rocket3004 View Post
A little more diagnostic work as suggested may help you definitively answer if it’s the head gasket or not. I agree with pressurizing the coolant system. If it isn’t the head gasket but just a coolant leak, this may help you figure out where it is which would
Be a win as well. You can rent a tool from your local auto parts store and it doesn’t require any special tools.
A leak down test might be helpful, but only if you are having issues with the gasket sealing around the combustion chamber. That does require an air compressor though. I’d for sure start with the coolant pressure test first.
The combustion gas in coolant tester may be an option but I don’t have much luck with it in my hands
Me either. Mine was inconclusive at best. Supposed to turn yellow, just changed to a bluish-green color.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 12:17 PM #17
Swimupstream Swimupstream is offline
Swimupstream is on a distinguished road
Well, everyone was virtually spot on.
End of story: When I get out tomorrow morning I'm picking up my truck from the mechanic.
Didn't get to do the work Monday... called in to work Sunday so Monday was way off. Ran to pick up a Craigslist paddleboard downtown.... About halfway down the interstate wasn't wanting to go faster than 50 without a bit of a punch of gas.... did it again... then a sudden tick-tick-tick-tick-tick and a burning odor.
Played that game before, wasn't about to screw around to see what happened. Got it on the shoulder and idled it (yes I know) off the next exit.
Couldn't find anything immediate, but did notice it was wet on the front of the block.
Let it sit a bit to cool off in the rain. Oil level was on the lower side of full, color and consistency was good. Didn't work too hard at nailing down the source of wet, just no dangling hoses or blown stems/necks obvious. Tried a quick turnover of the engine and that did NOT sound good. Left it alone and flatbedded it.
That was evening. Left a msg for the mechanic. At 1130 the next morning he left me a message-- all done!
Misfire on #6, blew the plug out! (Says he's rarely seen it and he's been around, and a couple small ideas why.) Melted the coil. He pulled the coil, cleaned it out, re-tapped it (couldn't get the new one to seat), new coil and plug, topped it off-- voi la!!!!!!! Smooth idle. (clearly I did a pretty poor assessment under my frustration if I couldn't see that)
He ran a pressure test after me talking about the disappearing coolant... a couple of minor leaks at the main hose and at the water manifold that I disassembled and cleaned up last September when I replaced the water pump-- enough to be slow enough to leak and evap without dripping down or leaving obvious residue.
He's admits it's not 100% on the coolant leak right this second, but said he's seeing nothing else that indicates a head gasket at the moment or reason to dig deeper until I notice it continuing to happen.
Way out of my scope of practice and skill, even as simple as it would be to learn it all. Heck, the re-tapping and the pressure test alone were worth every penny-- $350 for the whole gig!
Guess God took that one out of my hands out of pity of me spinning my wheels... would have been another 2 months for me poking around and back and forth!
Keep an eye on it for a while and see what happens!
Thanks gang.
2005 4R SR5, 4WD V6
Clearly I'm not a motorhead, like spending as little as possible, but don't mind working and trying new things.
Swimupstream is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 12:20 PM #18
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Well that's a hell of a win.
I would immediately retorque the other 5 Plugs... odds are whoever did the last set didn't torque em down properly.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 12:53 PM #19
Hell yeah.
Good thought... I haven't touched the plugs (did #3 a few years ago) for 73k since I had the engine overhauled after I bought it...
2005 4R SR5, 4WD V6
Old 11-11-2021, 12:55 PM #20
Thumbs up
Y'know, I never did post the final finding on the disappearing coolant.
Kept losing it after this and just couldn't find the wet spot or any drips. But nothing else said head gasket... Then I poured the rest of the gasket repair in and waited... and waited... and checked--- ah.. maaaaybe..... and checked... and checked again--- Voila!
The head gasket repair was just being coolant leak repair! (which would have been a boat ton cheaper!)
Shows you how good my observational skills are... Look at all the crap built up on the connection of the main coolant recirc hose!!!! Who in the heck would have missed that?! (Me) It's SCREAMING Leak is here!!!! Not to mention the drip line on the bottom of it.
You can also see clearly the dried coolant (white stains) on the S hose from the water manifold (I believe it's a recirc line?).
Tightened down the coolant hose and got a new spring clamp for the S-hose... and (even today, 5 months later), coolant level hasn't dropped a millimeter!
All that headache and anticipation and worry and calculating. But y'know what... I learned a lot, I was humbled for not paying closer attention to the minor stuff, and made some new friends.
Thanks gang, hope this helps someone!
Shared album - JR Haole - Google Photos
(Let me know if these photos don't populate)
2005 4R SR5, 4WD V6
coolant , gasket , good , problem , week
Damn it !!! Disappearing Coolant !!! Mellemel 3rd gen T4Rs 25 11-17-2022 07:26 AM
Coolant doing a disappearing act chompster4runner 4th Gen T4Rs 9 05-09-2019 09:36 PM
v6 low idle followed by shudder and RPM increase. Clean MAF? Quiero 4th Gen T4Rs 9 01-13-2019 06:20 PM
Can anyone please help me with front brake shudder/shimmy problems??? OMG lfisherking 3rd gen T4Rs 13 11-17-2017 10:05 PM
What isn't wrong!? Coolant Explosion, High Idle in P/N, not D/R ToyotaGirl688 Classic T4Rs 5 04-06-2014 07:08 PM
