Old 06-11-2021, 08:30 AM #1
jgravlin jgravlin is offline
jgravlin is on a distinguished road
Having Misfire codes P0300,P0302, P0303
This issue started on a trip in the mountains misfires from a complete stop at low rpm, but above 2300 rpms the engine is strong and no misfires. I have codes P0300, P0302, P0303. Had to drive it home 2 hours it would only misfire below 2300 rpm more so around 2000 rpm intermittently. When I got home I checked cylinder 2, and 3 spark plugs they look normal which I figured they would. I then moved coil 2 to position 6 and coil 3 to position 1 and drove vehicle misfires started after the 4runner is warmed up and still misfires from idle to about 2300 rpms intermittently (I changed all plugs and coil packs about 4000 miles ago). Now I only have P0300 not sure where to go from here because the engine runs so strong perfect above 2300 rpms. If I try WOT from a stop engine misfires intermittently until about the 2300 rpm mark then runs great. This is a 4.0L.
2004 V6 4Runner=Dobinson's Front IMS59-50220 with OME 884 coils, Rear GS59-701 with OME 895 coils (these are awful stiff) will be changing to C59-675V, JBA upper control arms, custom extended rear sway bar links, Victory 4x4 roof rack, Tuff Stuff overland roof top tent, Falken wildpeak 285/70/17, Eagle alloy bullet hole wheels 9" wide -8 offset, BMC.
jgravlin is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 03:45 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
Are you losing any coolant?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 06-11-2021, 06:15 PM #3
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
I'd start with a compression test. If that's good check fuel trims.
As mentioned above, check coolant level... Could be hwad gaskets (may show in compression test)... I just did my head gaskets on my 04... But cylinder 4 and 6 are more common. FWIW i had 0 misfires.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 10:21 PM #4
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I had a very similar situation about a year ago. The two cylinders you named are on different banks with different coils and different injector drivers so if yours, like mine, started misfiring on both of them at the same time you probably have a similar problem to mine. It didn't make any sense, (I'm an ASE Master Tech), and so I ended up calling the Identifix Hotline. The most important thing I learned from the Toyota expert is that you can't trust the Toyota misfire monitors. I'm almost positive mine was on #2 and #3 also. So it's very likely that only one of them is misfiring, (that's how mine was). I'd suggest disabling one cylinder at a time while the engine is misfiring. To do that just unplug the connector at the coil. If it doesn't misfire at idle you may have to get someone to powerbrake it to make it misfire. Whichever cylinder doesn't affect the running of the engine when you disconnect the coil is the dead cylinder. As weird as it may be, mine turned out to be a spark plug. I replaced the plugs and it's run great ever since. If I had just replaced the plugs to start with I could've saved a lot of frustration and the cost of the call to Identifix. But I wouldn't have learned about the unreliability of Toyota's misfire monitors. The guy said you simply can't trust them. He was right in my case.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 06-12-2021, 10:33 PM #5
I drove the vehicle for a while and finally got it to throw codes for cylinder 1 and 6. As crazy as it sounds both coils went bad at the same time. I replaced them and all is good now thanks for all the suggestions.
engine , intermittently , misfires , rpm , rpms
1999 3RZ Misfire Codes P0300, P0303 NEED HELP SDsurfx 3rd gen T4Rs 23 07-04-2022 12:48 PM
Multiple random misfires,p0300, p0302, p0303 earthrealm 4th Gen T4Rs 24 01-20-2020 02:59 PM
Misfire P0300, P0302 and P0305 and loose crank pulley? Oliver4R 3rd gen T4Rs 1 06-29-2018 05:11 PM
Multi misfire P0300, P0301, P0302, P0303 kakarot 3rd gen T4Rs 3 12-24-2012 11:36 PM
Help! Got P0420, P0300, P0303, P0304 codes. sgt rock 3rd gen T4Rs 1 06-08-2011 11:18 PM
