Old 06-11-2021, 04:18 PM #1
alaskaman's Avatar
alaskaman alaskaman is offline
alaskaman is on a distinguished road
alaskaman's Avatar
Shuddering pedal and wheel
Figure I need to have the rotors turned. Taking it in for the brake "special". I know that Toyota has several different quality pads....I'll go for the upgrade.
170K miles now. Have replaced front and rear twice so far.
Any other items to check?
Thanks
2007' V6 SE 4WD PIAA 520's.
Yakima Load Warrior
Michelin LTX M/S 265 65 17
Westin Bull Bar Weathertech Mats
Bilsteins 5100's
alaskaman is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 05:10 PM #2
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Thanks
You will probably find your Toyota dealer (and most other shops) will recommend replacing your rotors instead of turning them. In my experience, as long as good quality rotors are used, it's actually better in the long run. Your dealer will use OEM rotors which are just fine.
As for pads, yes, there is a lower cost pad that is sometimes included in brake "specials." Skip it and go for the same pads that came in your vehicle. They don't coast that much more. Do not get tempted to go to the TRD performance pads though. Yes, they do stop a bit better, but the amount of dust they generate just isn't worth it. Oh, and they don't last as long either.
If you haven't had your calipers replaced yet, they will probably recommend it. For peace of mind, I'd recommend it too. You don't want to wipe out a brand new set of rotors and pads when an old caliper locks up.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 05:48 PM #3
alaskaman's Avatar
alaskaman's Avatar
Total cost with new rotors, calipers and pads could run about $1,200 at the dealer
Pricey.
Yakima Load Warrior
Bilsteins 5100's
Old 06-11-2021, 05:56 PM #4
Pricey.
It won't be cheap. (I work at a dealer.) You will get the very best parts though. Another alternative would be to have a private shop you can trust do it with high quality aftermarket parts. If you pick the parts carefully - maybe even use OEM - you can probably get the cost down.
Old 06-11-2021, 08:52 PM #5
montijo505's Avatar
montijo505's Avatar
Calipers don’t need replaced unless they are seized or corroded. Replace the pads and rotors and call it a day.
Old 06-13-2021, 10:10 AM #6
alaskaman's Avatar
alaskaman's Avatar
Taking it in early Monday. Will let ya know. probably. Many of the miles have been in sub zero temperatures with snow and ice which can be much fun.
This vehicle is my Beast. This was my post after purchase 2007.
The Beast Meets Snow. Pirelli Scorpion ATR
Yakima Load Warrior
Bilsteins 5100's
Old 06-14-2021, 07:21 PM #7
alaskaman's Avatar
alaskaman's Avatar
Had the work done today. rear brakes were 7/10 fronts were 4/10. Roter still within specs so they machined the front. Calipers were good and they replaced the front pads. Had the brake fluid flushed and same with the power steering.
Would have totaled out just brakes $410. Flushes were $149. each. Not pretty on the bank account but it's done.
Pretty clear to me that everything now with the democrats and post covid are more expensive.
They also told me the front axles were leaking and should be replaced....$750.00 I am going to call around as it was obvious that was selling up.
Yakima Load Warrior
Bilsteins 5100's
170k , miles , replaced , shuddering , upgrade
Shuddering When Gas Pedal is Pressed CowboyBob 3rd gen T4Rs 6 11-14-2017 06:00 PM
Shuddering when braking Rishi3 4th Gen T4Rs 4 01-02-2017 01:28 PM
Shuddering from stop sooner02r1 3rd gen T4Rs 7 05-25-2014 07:34 AM
2004 Shuddering tri2006 Problems & Warranty Issues 0 05-31-2006 11:58 PM
shuddering 04 Sport V8 ted 4th Gen T4Rs 8 01-27-2005 02:10 AM
