Old 06-13-2021, 07:32 PM #1
steven1955 steven1955 is offline
steven1955 is on a distinguished road
Airlift 1000 Airbags: Alternate Schrader Valve Locations
I am getting ready to install Airlift 1000 airbags in our 2007 V8 Limited. I see a lot of folks install the Schrader fill valves in the rear bumper cover so that the valves are hidden when the rear hatch is closed. But.... We travel with a receiver hitch bike rack so it would be a real pain to open the hatch to change the air bag pressure if we use that location.
Has anyone found a good alternative Schrader valve location that allows access without opening the hatch?
steven1955 is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 09:53 PM #2
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Mine are at the bottom of the bumper, very stealth but very accessible. I'll take a pic tomorrow
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 06:39 AM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i have drilled a hole at the trailer plug bracket, just at the corner for easy access.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 11:10 AM #4
Hi Warwicke36 and riceandpho,
Would either or both of you guys say your Schrader valves would be easily accessible if you had a bike rack mounted with two bikes?
I had thought about mounting my Schraders in the trailer plug bracket but can't see me enjoying squeezing between the bumper and our bikes.
Old 06-14-2021, 01:39 PM #5
swampdodo swampdodo is offline
swampdodo has a spectacular aura about swampdodo has a spectacular aura about
I've seen people on the net put the valves next to the gas filler so it is protected by the locked gas door...not sure how easy or dangerous that would be for a 4Runner.
swampdodo is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 01:40 PM #6
...like this Tundra...
Airbag fill ports located in fuel door. | Toyota Tundra Forums
Old 06-14-2021, 03:05 PM #7
Warwicke36's Avatar
Warwicke36's Avatar
Super easy access even with my Rigd ultraswing. Would imagine bikes would be the same...
Super stealth IMO... I have one on each side in the same spot as I ran the lines separately from each other not 2 into 1.
Airlift 1000 Airbags: Alternate Schrader Valve Locations-20210614_074059_20210614150233894-jpg  Airlift 1000 Airbags: Alternate Schrader Valve Locations-20210614_074049-jpg
2004 Sport 4.0
Old 06-15-2021, 01:09 AM #8
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
I put mine underneath on the drivers side of my aftermarket tow hitch assembly. I didn’t personally like idea if it being in the hatch. Was afraid I’d bump or break them loading/unloading plus felt it was unsightly, albeit a convenient place in the hatch. Mine aren’t the most convenient location though having to get down and under to reach. Seems like the gas tank lid would be pretty convenient. I installed both on the same side for easier access.
I also installed a PNEUMADYNE pneumatic toggle switch and tied the lines together. With the flip of a switch the airlift bags can be independent or run on common line. Super convenient for airing up, down, and checking psi because you only have to use 1 Schraeder valve.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 04:14 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
This is how I did it on a different vehicle. Not having to crawl under was a huge plus in my opinion. May have looked a bit odd adding air in public areas seeing I used a bicycle pump.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 06-28-2021, 12:39 AM #10
This is how I ended up installing my two Schrader valves: I removed the two screws and plastic threaded inserts behind the rear driver's side wheel that fastened the rear bumper cover to the 4Runners frame. I then replaced the two screws and inserts with the two Schrader valves. No holes to drill and so is completely reversible should I decide to remove the airbags in the future.
Airlift 1000 Airbags: Alternate Schrader Valve Locations-pxl_20210626_205725806~2_2-jpg
airlift , hatch , location , rear , schrader
Alternate spare tire locations. Reasons, Pros, Cons. Road Bull General Discussions 16 12-20-2019 12:37 PM
4th Gen Toytec Super Flex HD Springs with Airlift 1000 Airbags Scat Adams For Sale: Suspension/Wheels/Tires 1 10-09-2018 07:56 PM
Icon Rebuild: Schrader valve or Charge Port grantprior13 4th Gen T4Rs 2 03-05-2016 10:59 PM
What type of Schrader valve for the AC? skott 4th Gen T4Rs 3 07-09-2015 11:04 PM
