Old 11-03-2023, 03:15 PM #1
thoff25 thoff25 is offline
thoff25 is on a distinguished road
HELP: weird electronic noise from dashboard while braking
November 3, 2023 - YouTube
Sometime it happens while I brake. Sometimes after, gets worse going downhill especially with weight in the car. Happens every few miles and the noise ranges from short bursts to long screech. Any thoughts ? 215k on the 2004 4Runner. Gotten worse over the last year. My assumptions point to master brake cylinder and or booster, but it is so loud its weird and I'm lost. Also, braking is fine otherwise, and no codes or dashboard lights. Also, no leaks fluid is maintained at proper level, I have even done brake flush and bleed too. Attached a video.
thoff25 is offline   Reply With QuoteReply With Quote
Old 11-05-2023, 04:54 PM #2
ace4aday's Avatar
ace4aday ace4aday is offline
ace4aday is on a distinguished road
ace4aday's Avatar
My first thought was the buzzer that goes off when I bleed the rear brakes, but you said you've done that, and I'm assuming it's a different noise. Hard to tell from the video.
2008 Sport V6 in Salsa Red
Ironman 4x4 Stage 2 FCP Lift (2.5"/2")
Vision Manx II Wheels
275-70-17 KO2 Tires
Victory 4x4 Blitz Front Bumper
ace4aday is offline   Reply With QuoteReply With Quote
Old 11-06-2023, 01:00 PM #3
FBELTRAN24 FBELTRAN24 is offline
Real Name: Llewellyn Moss
FBELTRAN24 is on a distinguished road
If this helps any, I own an 07' 4R Limited. Recently had a brake line leak(fixed) that was steady enough to obviously lower the fluid level in the reservoir. When the level became dangerously low/zero, I had a loud, LOUD screeching sound through the speakers until I fixed the leak, and added enough brake fluid to the system/reservoir. The sound immediately stopped, and the VSC/TRAC, and dash lights also immediately shut off.
FBELTRAN24 is offline   Reply With QuoteReply With Quote
Old 11-06-2023, 01:43 PM #4
Thanks, I will look at the brake lines (I do believe one of them is swollen, I replaced the front 2 to stainless). The fluid reservoir has been staying consistently full, just may be one of the pumps finally dying, but no dash lights. I'm sure they will come soon enough...
hurst , long , noise , short , worse
Very dangerous braking behavior after electronic brake booster module replacement Charles Bronson 5th gen T4Rs 19 04-13-2022 04:17 PM
Weird Electronic Anomaly with Rear Window bigbillyt 5th gen T4Rs 10 10-26-2016 09:12 AM
Got my electronic Climate Control replaced - now some weird problems! CZ Eddie 3rd gen T4Rs 2 12-18-2012 04:54 AM
Weird noise from underneath dashboard hulk311 Problems & Warranty Issues 3 09-10-2011 11:49 PM
Advice on purchasing an electronic weather/compass dashboard unit. doctorcarta Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-23-2007 10:55 PM
