Old 06-14-2021, 11:13 PM #1
vicho09 vicho09 is offline
vicho09 is on a distinguished road
IronMan 2" Suspension lift kit
Hey guys, first I want to thank you all for helping with my first post ever which was about an oil leak. Now in my second post I want to ask about the IronMan suspension kit.
I dont understand much about this, its a 2" lift, so does it add 2" to the front and back or is it an average? Also does this mean that the rake of the truck of 1" higher in the back as stock is kept?
Im thinking about buying this one since its the one available here in Chile, but i want to have the truck lifted 3" in the front and 2" in the back. So im wondering, can i add a 1" leveling in the front to this IronMan suspension so i can get the 3" front and 2" or does it not work like that?
I would also apprecciate any concerns or reviews regarding the IronMan suspension, since the last post i saw about it was 8 years ago. If not i would have to import a OME kit.
Thank You!!
vicho09 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 02:01 PM #2
pleasee
Old 06-16-2021, 06:27 PM #3
bmorey bmorey is offline
bmorey is on a distinguished road
Thank You!!
Hey man,
There's a thread called "The Ironman Suspension Thread" and it has 2 pages of info on the Ironman stuff for 4th gens.
I have the 2.5 in front, 2 in rear suspension lift from them and their UCAs. I'm very pleased with the on and offroad manners. See my post about it here
As far as lift goes, the truck is perfectly level with .5 inch higher in the front. Remember, the front geometry actually doubles the lift (so .5 inch "extra" = 1 inch actual lift up front). I am running 33's with the lift no problems.
2004 4Runner Sport Edition 4WD Titanium Metallic -
Ironman 4x4 Lift and UCAs, 33s Falken Wildpeaks, Custom 2-Drawer System, Prinsu Rack, Frontrunner RTT, Ironman 4x4 Awning, Cali Raised Sliders, 1 Inch BL, Lost Trails Low Profile Front Bumper, Badlands Apex 12k Winch
bmorey is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 09:27 PM #4
Originally Posted by bmorey View Post
Hey man,
Thank You a lot! In my country they say the kit comes with a 2" full lift, but i dont get how they say in the thread that it lifts more than 2". Could you fit the 33's with no trimming? Im trying to get those too but the kit is only the 2" one so i dont know if it will work, or i should get a levelling kit (1/2 ") that goes on top of the front shocks. I atached the picture of what they sell here. (equivalent to $1300 tax included)
IronMan 2" Suspension lift kit-ironman-jpg
Old 06-17-2021, 12:25 PM #5
I would give it a go. I think that kit might level your truck as itís sold. If not, adding a spacer later isnít super difficult.
And yes, i fit the 33s just fine without trimming. I have 285/70/17 Falken Wildpeak AT3Ws
Old 06-17-2021, 03:46 PM #6
I reallyy like your built and itís what Iím looking to make mine look like. Last question, do your wheels have any offset or did you put wheel spacers?
Old 06-18-2021, 04:26 AM #7
njauregui njauregui is offline
njauregui is on a distinguished road
Did you have to do any alignment mods like maxing out the caster? I have the same set up as you except I have OEM UCAs. But I do plan on putting 33s but thinking about clearance issues. Trying to avoid bmc. Iím assuming you didnít have to do a bmc?
njauregui is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 08:40 AM #8
Thanks! Yeah i have 1.25 spidertrax. The trail wheels i have from a 2012 4Runner are +15mm offset (meaning about .5 inch inboard). With the spacers, i actually started rubbing more. I wouldnt recommend the spacers unless youíre ready to start trimming things and maybe a BMC.
Old 06-21-2021, 08:45 AM #9
Good question: so with the Ironman UCAs, they come with 4 degrees extra caster built in. So i actually had no rubbing issues at all with factory alignment specs.
Then i added wheel spacers (see my reply about this above). With the wheels out an extra 1.25 inches, i started rubbing badly. Using the extra caster possibilities from the Ironman UCAs, i talked to the alignment shop and had them set the caster near 3 degrees positive - no issues since!
And no BMC.
Old 06-22-2021, 01:49 AM #10
roy326 roy326 is offline
roy326 is on a distinguished road
Smile
As posted above, Ironman 4x4 uca has 4 degrees castor. I have 285 75r16 and experience on rub in the front and no BMC. When rock crawling, the rear does rub against the rear bumper. I will cut that before I got out next time
Wheels are 0 offset 16x Ö I forgot
IronMan 2" Suspension lift kit-aec18152-f362-4637-9ade-165b7f07ca78-jpg
03 4runner V8 4x4
12 GX460
17 Tacoma OffRoad
roy326 is offline   Reply With QuoteReply With Quote
back , front , ironman , post , suspension
Anyone running 295 with Ironman suspension Flea7907 5th gen T4Rs 2 07-02-2020 05:53 PM
FS: ironman 2" nitro gas suspension kit for 4g T4R and GX470 BNIB Atlanta, GA Bar4x4 For Sale: Suspension/Wheels/Tires 3 03-14-2020 07:39 PM
Anyone have experience with Ironman suspension lift? 1985taylor1925 3rd gen T4Rs 12 11-20-2019 04:42 PM
5th Gen - 2.5" lift by Ironman - $350.00 - Portland, Or. nwoutdoors For Sale: Suspension/Wheels/Tires 2 10-25-2015 10:36 PM
Pic request: post up your pictures of a ~3" suspension lift + 1" body lift. 98LtdT4R 3rd gen T4Rs 4 12-07-2013 11:25 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
