Old 06-21-2021, 02:59 PM #1
bill444 bill444 is offline
bill444 is on a distinguished road
ODB-II for 2003/2004
Hello,
Does anyone here own a 2003 or 2004 4Runner and have a scanner that does not reset the zero point calibration? I am asking about these years because I think 2005+ use CAN instead of ISO for ODB-II.
My ScanGauge works fine because I can hard code ISO instead of CAN. However, I am looking for a traditional reader with a display for troubleshooting.
Everything else I own starts by scanning with different protocols before it tries ISO. This always resets the zero point calibration and my VSC TRAC is disabled as a result. I've been to fix it each time but it is time consuming.
Thanks
Bill
bill444 is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 03:23 PM #2
riverwolf riverwolf is offline
riverwolf is on a distinguished road
I guess I'm not sure what exactly you're asking. I use Torque (Lite/free edition) with a compatible Bluetooth ODB2 adapter to read/clear codes and monitor whatever other engine data gets exposed via ODB2 without issue (O2 sensor voltage, coolant temp, intake air temp, etc.). Doesn't seem to automatically reset or disable anything that I can tell. Just used it last week to confirm my recent CEL/ATRAC/VSC trifecta was in fact just a loose gas cap from my last fill-up.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 03:44 PM #3
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Arrow
Has to do with the battery disconect.
If you disconnect the battery with the sg2 connected it will mess up the ABS stuff.
Have to then reset the ZPC.
Have to connect the SG2 with a running t4r.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 04:06 PM #4
For the scan tools I own, they all disable VSC because the scanner trips the zero point calibration when it tries the CAN bus protocol. I searched a few reviews on Amazon for a new scanner and some really nice ones also report this issue with a 2003/2004 4Runner.
I guess some scanners, like the one you own, try ISO first and because they never try CAN bus, the issue doesn't happen. I will see if I can buy a Torque.
Thanks
Old 06-21-2021, 04:06 PM #5
Thanks, good to know.
Old 06-21-2021, 07:02 PM #6
Real Name: Skip
Real Name: Skip
Thanks
Just an FYI "Torque" is an app not a scanner per say, there's a free version of the "Torque" app, Torque Lite and a Pro version that they charge a small fee for.
Torque — OBD2 Performance and Diagnostics for your Vehicle
Torque Lite (OBD2 & Car) - Apps on Google Play
Torque Pro (OBD 2 & Car) - Apps on Google Play
Both versions have to be used with a compatible OBDII dongle that you plug in the OBDII port and then connect via Bluetooth with an Android phone, as far as I know there's not a version of Torque that is compatible with Iphone.
My phone I use everyday is an Iphone but I have an old Android phone that I used with Torque.
There are many OBDII dongles out there that are compatible with Torque, the one linked below is the one I have and some other members here also use this dongle.
Amazon.com: Bafx Products - For Android Only - Wireless Bluetooth Obd2 Scanner Diagnostic Code Reader & Scan Tool - Scan, Reset & Clear Car Check Engine Light: Automotive
This OBDII dongle is also compatible with many other diagnostic apps that you may want to try as well if you find you don't like the Torque app but most people use Torque.
You can find a list of other apps on their website.
BAFX Products(R) - Wireless Bluetooth OBD2 Reader / Scanner for Android Devices
2004 Limited V8
Old 06-21-2021, 08:37 PM #7
Thanks. I think it might be easiest/lowest cost for me to build a short ODBII pigtail cable that removes pin 14 entirely since it's not needed for the earlier cars.
This way my existing Thinkdiag iPhone scanner and my cheap handheld units can't screw up the zero point calibration because they won't have access to pin 14.
I'll update the thread if that works once the parts arrive. Should be less than $10.
Old 06-22-2021, 12:08 PM #8
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
Never had an issue on my '03... not with a scanner nor with my regularly used Torque app/bluetooth OBII adapter I use to connect it to..
aemravan is offline   Reply With QuoteReply With Quote
Old 06-23-2021, 03:50 PM #9
Yeah, I can't believe I've had such bad luck. I found good threads here explaining why it happens. If the scanner does not try can bus first, it won't cause the problem. Every one of mine tries can bus (new trucks) before ISO 9141 (older trucks) or whatever it is called. Every time I have to do the zero point calibration reset routine.
One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration
Old 06-23-2021, 04:25 PM #10
MikeinNH67's Avatar
MikeinNH67's Avatar
My old Scangauge sets off all the lights if I try it on my 03. Back in 2016 I bought one of these and no issues with it on the 4runner. Cheap enough and it's still going strong after 5 years.
Amazon.com: Veepeak Mini WiFi OBD2 Scanner for iOS and Android, Car OBD II Check Engine Light Diagnostic Code Reader Scan Tool Supports Torque Pro, OBD Fusion, Car Scanner App: Automotive
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 10-14-2021, 11:16 AM #11
2003V8LTD 2003V8LTD is offline
2003V8LTD will become famous soon enough
Hello,
Thanks
Bill
I have an early '03 V8 and plugging in a scanner (at least, my cheapo Chinese one) does trip the VSC idiot light then it has to be reset. Easy enough, but a pain in the neck. There's something about many modern OBD2 scanners that just doesn't agree with early Gen4 diagnostic systems.
However, I tried the BlueDriver bluetooth scanner -- i.e. the type that connects to your iphone -- and it didn't trip anything. It's a fair bit more user-friendly and you can just leave it plugged in if you want. There are several other varieties of bluetooth scanners out there too.
2003V8LTD is offline   Reply With QuoteReply With Quote
calibration , iso , odb-ii , point , time
WTB: 4th gen 4runner v8 2003-2004 in NC $10k bdjcl For Sale: Vehicles 0 06-21-2019 11:51 AM
2003 vs. 2004 4Runner? Strider 4th Gen T4Rs 11 01-26-2018 11:57 PM
WTB: 2003/2004 SR5 4x4 AZ afuller001 For Sale: Vehicles 0 05-08-2015 07:44 PM
Trade 2003 to 2004? 20034RunnerV84x2 4th Gen T4Rs 49 06-04-2012 02:07 PM
2003-2004 V6 2WD Gas mileage PT2002 4th Gen T4Rs 22 08-20-2004 10:17 AM
