Old 07-06-2021, 09:59 AM #16
beezee beezee is offline
beezee is on a distinguished road
Originally Posted by MikeinNH67 View Post
Looking forward to see what you find. Good job getting those exhaust manifold bolts off but maybe easier in CO.
I sprayed the bolts with PB Blaster a day before I started so it helped some. Ended up rounding a nut on the passenger side but an extractor came in handy.
Sent from my SM-N986U using Tapatalk
2003 v8
2005 v6
beezee is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 10:06 AM #17
So I realized after the fact that I wasn't supposed to remove the torque converter with the engine. The service reps at Toyota was kind enough to allow me to speak with a lead tech who said I didn't screw up yet. He told me to replace the front pump seal ($15~) which he knows for a fact tore while removing the engine and TC.
2003 v8
2005 v6
Old 07-06-2021, 10:08 AM #18
More photos...2005 T4R v6 engine knock | Engine Rebuild-20210704_170459-jpg2005 T4R v6 engine knock | Engine Rebuild-20210704_172707-jpg2005 T4R v6 engine knock | Engine Rebuild-20210704_184417-jpg
2003 v8
2005 v6
Old 07-06-2021, 10:12 AM #19
Blown headgasket? I didn't expect to see this.2005 T4R v6 engine knock | Engine Rebuild-20210705_134351-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_134346-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_134340-jpg
2003 v8
2005 v6
Old 07-06-2021, 10:17 AM #20
After watching a bunch of videos on youtube...(I know...I know..) I was expecting to see a chewed up connecting rod bearing on #4....well it was much more than that.
Piston #4. The last photo is coolant in #6 cyclinder.2005 T4R v6 engine knock | Engine Rebuild-20210705_134413-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_134419-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_134431-jpg
2003 v8
2005 v6
Old 07-06-2021, 10:27 AM #21
UH-OH!2005 T4R v6 engine knock | Engine Rebuild-20210705_140615-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_140533-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_140602-jpg
2003 v8
2005 v6
Old 07-06-2021, 10:30 AM #22
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough
Real Name: Armando
I'm amazed at the skill involved in doing this project. Hats off to you my friend. I have a 2005 and I'm keeping it a long time, 180,500 miles strong.
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 12:18 PM #23
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a jewel in the rough rdruss is a jewel in the rough rdruss is a jewel in the rough rdruss is a jewel in the rough
rdruss's Avatar
Real Name: Ron
Yep, must be a rod bearing spun and why piston/valve contact.
Old 07-06-2021, 04:00 PM #24
More bad news... definitely spun a bearing. The crankshaft cap bearings very worn as well.
Engine block and crankshaft may be toast. Very concerned about those deep scratches below the cyclinder wall.
Taking block and heads to machine shop tomorrow.2005 T4R v6 engine knock | Engine Rebuild-20210705_171744-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_171736-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_145507-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_145451-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_143409-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_143258-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_141023-jpg2005 T4R v6 engine knock | Engine Rebuild-20210705_141014-jpg
2005 T4R v6 engine knock | Engine Rebuild-20210705_143241-jpg
2003 v8
2005 v6
Old 07-06-2021, 04:05 PM #25
Thanks man. Learning a lot along the way labeling everything I can.
2003 v8
2005 v6
Old 07-06-2021, 04:15 PM #26
Originally Posted by Drcoffee View Post
Have you called any dismantlers on what used engine would cost you? You will NEVER rebuild it back to original toyota specs. These engines are precisely built in clean rooms by experts. It may sound like fun until it grenades on you. Just sayin
Drcoffee,
I do get the point you are trying to make but I need the challenge and with the help of this forum, it can be done. I really hope I can avoid the grenade part though.
2003 v8
2005 v6
Old 07-07-2021, 03:27 PM #27
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Crank definitely scrap, but block and heads should be salvageable.
Old 07-07-2021, 08:10 PM #28
MikeinNH67's Avatar
MikeinNH67 has a spectacular aura about MikeinNH67 has a spectacular aura about MikeinNH67 has a spectacular aura about
MikeinNH67's Avatar
Ouch, that's a lot of carnage. Good on your for tackling this but personally I would get a used engine. It would always be in the back of my mind that I may have missed a damaged piece.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-07-2021, 10:39 PM #29
plutonic's Avatar
plutonic plutonic is offline
plutonic is on a distinguished road
plutonic's Avatar
The damage is fixable in my humble opinion. The crankshaft can be definitely fixed...re-grinding and polishing can be done by a specialty shop and oversized crank shaft bearings can be used.
plutonic is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 07:55 AM #30
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is a jewel in the rough Drcoffee is a jewel in the rough Drcoffee is a jewel in the rough
Drcoffee's Avatar
My vote would be, buy a used engine, replace the timing chains while its out, and get the truck running again.
Keep the pile of bits so you can tinker with rebuilding it and then trash it. If you had bottomless pockets and a full machine shop at your disposal, I’d tell you, your nuts, go buy a used engine.
1999 4Runner SR5 4WD 3.4L AT 232,000 miles
2007 4Runner Sport 4WD 4.0L 222,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP
Drcoffee is offline   Reply With QuoteReply With Quote
asked , back , engine , rebuild , service
Engine 'Knock' problem AntleredRuin 3rd gen T4Rs 13 09-08-2020 03:00 PM
Engine go Knock Knock= Planning Time..... Ol'Blue 3rd gen T4Rs 17 01-27-2016 10:55 AM
Engine Knock neo mrosko 3rd gen T4Rs 1 05-02-2011 11:57 AM
95 3.0 engine knock anfdavis Classic T4Rs 1 01-24-2011 01:29 PM
92 - Slight Engine Knock 92TXT4R Classic T4Rs 2 12-04-2009 02:18 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
