Old 07-08-2021, 08:26 AM #31
Piggity Piggity is offline
Piggity will become famous soon enough
Originally Posted by Drcoffee View Post
My vote would be, buy a used engine, replace the timing chains while its out, and get the truck running again.
Keep the pile of bits so you can tinker with rebuilding it and then trash it. If you had bottomless pockets and a full machine shop at your disposal, Id tell you, your nuts, go buy a used engine.
This is what I would do as well. All of those bearings are trash, crank is f'd from all of the washout of the head gasket leak, a couple rods are cut/broken??, it's not going to be cheap to fix all of this.
06' Limited 4WD V6 Nautical Blue Metallic
5th Gen front brakes
265/65R18 Cooper A/TW tires
2018 Forest River 201BHXL
Piggity is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 05:14 PM #32
beezee beezee is offline
beezee is on a distinguished road
I was not expecting to see that much damage and got completely discouraged trying to continue the rebuild process. I wasn't even able to get the crank out of the block.
The block, heads, cams, pistons, connecting rods, caps, bearings are at a machine shop and they will let me know what's salvageable.
As a backup, I'll be trying to source a motor from pull-a-part in the mean time.
I appreciate all your comments.
bz
Sent from my SM-N986U using Tapatalk
2003 v8
2005 v6
beezee is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 07:25 PM #33
Someone local to me said he has an 08 engine for $3200. What do you guys think? He'll give me the mileage tomorrow.
bz
2003 v8
2005 v6
Old 07-08-2021, 07:42 PM #34
Nevermind. After reading this thread, it's probably more headache than it's worth.
Quick question on an engine swap. - Toyota 4Runner Forum - Largest 4Runner Forum
2003 v8
2005 v6
Old 07-09-2021, 11:28 AM #35
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Beeze, roughly speaking, what was your anticipated budget and hours for a quality rebuilding with OEM parts? Before and after you discovered the extent of the damage.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 07-09-2021, 05:47 PM #36
3k on a rebuild. Time wise....3-4 hours every evening until it's done.
2003 v8
2005 v6
Old 07-10-2021, 05:09 PM #37
triethylborane triethylborane is offline
triethylborane will become famous soon enough
Have you called any of the salvage yards like Yoda Jim? I think hes out on I76/I270 exchange. Maybe he can get a bead on a lump for you.
triethylborane is offline   Reply With QuoteReply With Quote
Old 07-11-2021, 05:34 AM #38
Bundutrailer Bundutrailer is offline
Bundutrailer is on a distinguished road
bz
What triggered all the failure, is it just bad luck?
Bundutrailer is offline   Reply With QuoteReply With Quote
Old 07-11-2021, 10:03 AM #39
I bought the vehicle knowing it had engine knock. Im guessing bad/improper maintenance had a lot to do with it and most likely started with a blown headgasket.
2003 v8
2005 v6
Old 07-11-2021, 11:52 PM #40
y=mx+b's Avatar
y=mx+b y=mx+b is online now
y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold y=mx+b is a splendid one to behold
y=mx+b's Avatar
From what I understand, you can't mix v6 engines from 03-04 with 05-09 engine because the both use different transmissions, and also have difference ECM communication protocals. with an 05, an 08 engine on paper should work out
y=mx+b is online now   Reply With QuoteReply With Quote
Old 07-12-2021, 01:54 PM #41
So, I am going to scrap rebuilding this engine since I do not have unlimited funds. I also shared the photos of the carnage above with a tech at Toyota who confirmed the block is toast.
The machine shop quoted me $1800 in labor only for the heads and block work, no parts included.
I have two leads on an '07 with159,000 miles and and '08 with 161,000 mile engine right around 3k. Should be done with this by this weekend going this route.
bz
2003 v8
2005 v6
Old 07-12-2021, 03:40 PM #42
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a jewel in the rough rdruss is a jewel in the rough rdruss is a jewel in the rough rdruss is a jewel in the rough
rdruss's Avatar
Real Name: Ron
bz
Famous last words!
Old 07-12-2021, 03:56 PM #43
The engine is the same, just with an updated head gasket from what I've heard. The ECU and transmission just bolt up to the actual engine so there should be no issue at all with using a later model (06-09') engine in his 05' - same with any sensors attached to the engine that may have changed thru the years.
Old 07-12-2021, 04:01 PM #44
Originally Posted by rdruss View Post
Famous last words!
LOL...Well...
With the engine core at $150 I might keep the darn thing. '08 Taco engine comes with 1 yr warranty vs 90 day warranty on the 07 4runner.
2003 v8
2005 v6
Old 07-12-2021, 04:13 PM #45
Has anyone see this before?
Attachment 384637
2003 v8
2005 v6
asked , back , engine , rebuild , service
Engine 'Knock' problem AntleredRuin 3rd gen T4Rs 13 09-08-2020 03:00 PM
Engine go Knock Knock= Planning Time..... Ol'Blue 3rd gen T4Rs 17 01-27-2016 10:55 AM
Engine Knock neo mrosko 3rd gen T4Rs 1 05-02-2011 11:57 AM
95 3.0 engine knock anfdavis Classic T4Rs 1 01-24-2011 01:29 PM
92 - Slight Engine Knock 92TXT4R Classic T4Rs 2 12-04-2009 02:18 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
