06-27-2021, 05:49 PM
CEL - P0304 Code
I had a shudder the other day and this code popped up. P0304: Misfire Detected → Cylinder 4
After that, didn't notice any difference and cleared the code to see if it would come back. Just came back yesterday but again, don't really feel anything.
Any issues driving on this until I can get it checked out? Also, anyone had this before? I haven't seen any smoke in my exhaust so not sure if it is a constant thing or just a hiccup.
2006 4Runner Sport Edition 4WD V6
Dobinsons 2.5"/1.5" - C59-302, GS59-221, C59-505, GS59-705 | General Grabber ATX 265/70R17 | TPMS Bypass Mod
Custom Storage Box/Sleeping Platform Build | Dedicated Transmission Cooler (Derale D13503) | Demello Offroad Sliders
06-27-2021, 07:32 PM
P0304 is a generic misfire code on cyl #4. Trouble shoot it. Swap coil packs 2 & 4 and see if the code goes to p0302. That rules out the igniter. Then swap plugs 2 & 4. Same goal. If it comes back as p0304 and its not electrical, then look at fuel injectors. Thats less easy because you need to remove the intake. Even numbered cyl are on the drivers side
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
06-28-2021, 11:40 AM
Awesome, that's a good plan. Do you know how long (miles driven or what) it takes for a code to reappear once cleared?
06-28-2021, 01:52 PM
Hard to say. I had a bad fuel injector once and it took about 1 mile before it got hot enough to act up again. You can check codes more frequently and look for pending codes.
06-28-2021, 09:32 PM
Good step-by-step rule out, I'd add a compression test during the plug removal step.
06-29-2021, 07:19 PM
Originally Posted by ieatfish
Swapped the coil today, no codes yet. If I'm extra lucky it was a poor connection!
How many miles on the spark plugs?
06-29-2021, 07:57 PM
I'm actually not sure, I've put about 15k on the 4runner since I bought it. It was one of those things where I thought if it ain't broke, don't fix it. They may be original so I honestly should probably check them...
07-01-2021, 12:31 PM
P0304 is now back as a pending code. I'll probably just go ahead and replace all the spark plugs just to be sure.
Any recommendations?
Plugs possibly, as the gap between the central and lateral electrodes increases, so does the voltage necessary to deliver the current across the gap. This increases the draw on the ignition coil.
Plugs and ignition coils are cheap, even the Denso items. Id replace the coil pack, get plugs, investigate the plugs during the coil pack r&r, then see how things shake out. The engines in the 4Runners are not demanding on the ignition coils (compression etc), but faults can occur on an individual basis within the coil, the ignition wiring, and plugs.
07-01-2021, 01:05 PM
If you swapped plugs, coils and still a p0304, I would swap the #2 & #4 fuel injectors. I bet its a faulty fuel injector.
But you have a 2006 which means it can also be a head gasket failing. In the morning before you fire it up, pull out #4 spark plug and see if you can see coolant in the cylinder. Maybe run a swab in there for wetness. That would be a worst case scenario and will cause misfires. Get a head gasket test kit and check for exhaust gasses in the radiator. Its normally #6 but I have seen threads with #4 blown too
07-01-2021, 02:06 PM
Plugs are next, I should have clarified "Any recommendations for plugs?".
However, for head gaskets I thought was resolved in the '05s?
07-01-2021, 05:30 PM
I thought some early builds in 2006 still had the issue. I have an ‘07 built in oct 2006. Just made the cut off
The original plugs were copper, I changed mine to Denso iridiums and. They run great, but you do need to gap them. They are too narrow out of the box. Too small of a gap will cause drivability issues. Get it right and they will run for 120-200,000 miles.
But before dropping $60 on plugs, check for coolant in the cylinder. You may just end up selling it
07-01-2021, 07:46 PM
Real Name: Skip
Real Name: Skip
@ ieatfish
, check the VIN sticker on the driver's door jamb for your build date, if the build date is 12/05 or later your engine has the new design head gaskets and shouldn't have any head gasket failure issues, some earlier build 2006s have the possibility of head gasket failure.
2004 Limited V8
07-01-2021, 09:47 PM
Originally Posted by AuSeeker
@ ieatfish
Thanks guys, I figured I'd bite the bullet and do the plugs since it hasn't been doing anything else, no lowering of fluid, and I checked for fluid in the cylinder and didn't see any. It is a 09/05 manufacture which is not my favorite thing to realize but I'm not terribly concerned.
Ended up swapping the plugs for some Denso 3421 Iridium plugs. The plugs in the block were half Denso and half NGK. That leads me to believe they were the original plugs!
We'll see how this goes, hopefully it isn't an injector or wiring as others have suggested but seeing how burnt out the old plugs are, I'm optimistic this was the culprit.
