Old 06-28-2021, 12:32 PM #1
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
Fuel pressure tester recommendations?
Anyone know of a Fuel pressure tester kit that has the right fitting to tap into to fuel line at the connection just before the fuel damper on V8?
I ordered this p.o.s. kit off amazon:
Amazon.com: BETOOLL Fuel Pressure Test Kit 0-100PSI with 9.49,7.89,6.30 Fuel Line Fittings: Automotive
It just sprayed gas everywhere because the cheap plastic clip that's supposed to hold the fitting in place won't hold.
Hunter61 is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 12:58 PM #2
most auto parts stores like auto zone or oreillys will rent one for free that should have the correct adapters.
Old 06-28-2021, 01:48 PM #3
Real Name: Steven
Real Name: Steven
Thanks firebirdguy but I got mine to work after playing around with it a bit.
Old 06-28-2021, 09:43 PM #4
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
I used that same kit # on my '07 V6 4Runner, and the quick-connect was a tight fit onto the chassis line...but with a light film of clean oil on the line surface it clicked into place.
waypoint is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 10:22 PM #5
Real Name: Steven
Real Name: Steven
I must have gotten a defective one then. The fit wasn't the problem, it was the plastic clip that was supposed to hold it on. It clicked into place alright but as soon as I started the engine that fitting blew right off spraying gas all over.
I put that larger clip on that goes over the normal fitting and it held it in place. I dunno, maybe I was supposed to do that to begin with?
Old 07-25-2021, 07:45 PM #6
arkansasdaniel arkansasdaniel is offline
arkansasdaniel is on a distinguished road
i checked autozone. didnot have one. have you rented from oriellys? will try
arkansasdaniel is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 07:47 PM #7
any idea what normal fuel pressure is supposed to be on 4.7 4runner
fitting , fuel , kit , pressure , tester
Fuel pump or fuel pressure regulator? ggrant Problems & Warranty Issues 4 09-29-2023 10:54 AM
Recommendantions for oil pressure tester Traveler74 3rd gen T4Rs 5 08-02-2020 08:40 PM
'19 5th Gen Fuel pressure/fuel system mugenrios2k Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-25-2019 08:38 AM
Fuel pressure tester Doc2012 3rd gen T4Rs 0 03-24-2016 09:31 PM
97 4Runner fuel tank building pressure/ wont take fuel Yotaoffroad27 3rd gen T4Rs 4 10-06-2015 10:34 AM
