Old 07-02-2021, 12:13 PM #1
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
Need advice: HID 4300K Xenon Depot or get the LED?
I purchased the HID 4300K kit 2 years ago and never installed because of all the mounting of the ballasts and other stuff. I just couldn't see how it would all go in the engine bay without getting ruined. Well, now I'm considering tackling again. I think I may know how to mount all of this stuff so I may do it.
However, for $135 there are apparently good LED Headlight bulbs that just plug right in! No fuss! No double sided tape or zipties or screwing into the sidewall.
What would you suggest? Say F' it on the HID kit and get the LEDs or use the HID kit?
The HID kit I have contains:
PWM Anti-Flicker Module
Relay Harness
4300K philips bulbs (I hear these can crap out after 2 years)
35W BAllastcs (digitical signal procecssor)
The way I see this thing, is there are 4 "little boxes that need to be secured" PER BULB. Seems ridiculous IMO.
I also swapped my headlight housing with this one a few years back.
Amazon.com: AnzoUSA 111320 Headlight: Automotive
HID and LED would work in that... I believe...
meltdowner is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 12:42 PM #2
kmeeg's Avatar
kmeeg kmeeg is offline
kmeeg is on a distinguished road
kmeeg's Avatar
I too changed from HID to LED. No more wire mess. Everything inside the housing, no drilling. I tried Nilight LED set (low beam + high beam) and very happy with the light output. I think the price is good for 2 sets (Low beam & High beam).
Just noticed they have extra $25 coupon in Amazon.
Nilight 9005/HB3 High Beam and H11/H9 Low Beam for 5th Gen 4Runner - YouTube
kmeeg is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 01:46 PM #3
Real Name: Tim
Real Name: Tim
You have a 4th gen right?
Old 07-03-2021, 10:02 AM #4
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
My experience with lighting is, most HIDs will illuminate the road or terrain better than most LEDs but I’ve had issues with HIDs flickering and/or not coming on at all when it gets cold. They’re just too finicky for me so I haven’t used them in years. I’ve had good reliability out of LED lights but they don’t pack as much punch as some HIDs.
I also replaced my headlight housings on my 4th gen years ago with some ebay specials. The projector was absolutely terrible with the OEM incandescent bulbs. The cutoff wasn’t clean at all and had weird hotspots projected on the road. I even purchased a set of semi-clean OEM housings that I was going to swap into place but first I thought I’d try some LED bulbs. Surprisingly, the LED bulbs made a huge difference. The cutoff is nice and clean now and no more hotspots, just decent lighting. YMMV.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 07-03-2021, 12:22 PM #5
trey99ek trey99ek is offline
trey99ek will become famous soon enough
I've had the HID kit from xenon depot for 10 years, same bulbs. The one ballast finally died so I got a new kit because the newer wiring is nicer. It's really easy to hide everything. I tucked it under the plastic trim on the 5th gen. I had the kit on my 4th gen and it wasn't a problem either.
Sent from my SM-G981U using Tapatalk
2008 Sport Edition - GONE
2020 TRD ORP
trey99ek is offline   Reply With QuoteReply With Quote
Old 07-03-2021, 09:36 PM #6
Real Name: Tim
Real Name: Tim
Thank you both for replying. I should probably try and mount the HID first to see how it is and just tear it out if it's crap.
Old 07-04-2021, 01:38 AM #7
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
keep your hid kit and use it, make sure to readjust your lights to the correct height. other than that, just zip tie the ballast. once you got that itch for better lighting, retrofit hid projectors is way better.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
4300k , hid , kit , led , years
**SOLD** Xenon Depot 4300K HID britton406 Classifieds - buy & sell (no commercial ads please) 4 05-30-2011 01:51 AM
Xenon Depot Volt 4300k H.I.D Kit Trouble man03999 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-28-2010 07:23 PM
FS: Xenon Depot 4300K H11 Xenon Headlight Kit Need4spdnb Classifieds - buy & sell (no commercial ads please) 9 07-09-2007 08:37 AM
Xenon Depot H11 4300K HID Kit Review in 2006 SE matoolie Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-11-2006 02:37 PM
