Old 07-02-2021, 12:17 PM #1
4thGen4.7 4thGen4.7 is offline
Real Name: Taylor
4thGen4.7 is on a distinguished road
Real Name: Taylor
4LO is Dead?
Such an unusual case I couldn't find anything in search. A few months ago a shop put in a a tcase from another v8, lightly used.
They just did some work on the A/C and when they put the dash back together the 4LO beeps and flashes... they're blaming it on the tcase... I used 4LO after they installed it tho and it worked fine.
Thoughts?
2004 Sport Edition 4.7L V8
4thGen4.7 is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 01:35 PM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I've heard of the knob on the dash getting stripped and not engaging the switch fully. Could be an electrical connection not fully seated on the switch, or the dreaded bad 4Lo servo on the Tcase itself.
Kind of broad suggestions I know, but start with the stripped knob and eliminate that first. It has tripped up a few people before.
Hope its a simple fix and good luck!
Edit: it could just be that when they reinstalled the dash, the knob was installed wrong with the 4Lo switch engaged and the knob in the wrong position. If the vehicle is not stopped and in neutral, this would cause the warning lights.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 02:30 PM #3
montijo505's Avatar
montijo505's Avatar
Yeah try taking it apart before anything else. Plenty of people that thought t case was dead when in reality an audio installer forgot to plug the switch in when putting the dash together.
Old 07-08-2021, 11:34 AM #4
Real Name: Taylor
Real Name: Taylor
I appreciate the suggestions guys, I brought it up with the tech and it sounds like he did a good bit of due diligence to try and find the issue. Apparently after the module under the dash was plugged back in the computer did a self test that showed the problem is in the actuator inside the tcase, basically saying it doesn't know whether it is in hi or lo. When they installed the tcase the computer hadn't done the self test so the issue never came up. So I either have to bypass (temporary?), or switch out actuator or tcase entirely.
Old 07-08-2021, 12:24 PM #5
Real Name: Brett
Real Name: Brett
Aww crap, yea that is the Achille's heel of the electronic activation on these trucks.
Hope you can get it fixed for a reasonable price. There are several threads dealing with this problem.
I've got a manual tcase I'm gonna install in mine soon. Not waiting until it quits working.
Old 07-12-2021, 11:24 AM #6
bowhunter53's Avatar
bowhunter53 bowhunter53 is offline
bowhunter53 is on a distinguished road
I just purchased a 2006 sport with 85k miles and I can guarantee it was NEVER in 4LO. Crawl under and tap the actuator (black box attached to the t case) with a rubber mallet and keep working the switch in and out of 4LO. Mine freed up after about 4 or 5 taps and is good as new. Keep working the switch daily for a week to be sure it continues to operate correctly.
2006 SE V8 with 85k miles!!, Salsa Red Pearl, back in the game after a 10 year hiatus! Let the mods begin!!
bowhunter53 is offline   Reply With QuoteReply With Quote
4lo , dash , flashes , put , tcase
Dead battery = Dead 4runner? PedroV 4th Gen T4Rs 12 02-21-2023 02:15 PM
Dead MattJakobs Group Buys 46 08-17-2017 06:34 PM
And the FJ is now Dead CRYA 5th gen T4Rs 75 08-30-2013 05:08 PM
Dead '98 FLEXincRunner Problems & Warranty Issues 0 06-02-2013 10:37 PM
I think she's dead etperez22 Classic T4Rs 1 02-28-2009 09:49 PM
