Old 07-02-2021, 12:45 PM #1
chasrrr chasrrr is offline
chasrrr will become famous soon enough
Extended Wheel Studs
Hey Gang,
I know this has been talked about on the forums here a bit. I’ve done my research and found that I can run ARP extended studs for my new wheel setup on my 07 4Runner. Only thing is the studs are on back order and are minimum 6 weeks out everywhere and are gonna run me around 400 CAD for the set for my truck. I even looked into ordering OEM studs from Toyota - both IS300 and Matrix studs. Found out both are 40mm in length (same as my 4Runner studs) so they will not work.
That all being said does anyone have any other options? I’ve found these supreme studs on Amazon but I’m not sure if they’ll actually work on a 4Runner as I think they are listed for a 2nd Gen Tacoma?
Amazon.com: Supreme Suspensions - 12x Extended Wheel Studs Kit for All Toyota Tacoma with M12X1.5 Studs [Front or Rear Wheels]: Automotive
Let me know thoughts and if anyone has any other ideas.
Cheers!
chasrrr is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 12:53 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
They give you the dimensions so you should be able to figure it out.
Old 07-02-2021, 02:32 PM #3
montijo505's Avatar
montijo505's Avatar
Double check somehow but 2nd Gen Tacoma’s and 4th gens take the same wheel bearings, so studs should be the same as well.
Edit: they should work.
Old 07-02-2021, 05:30 PM #4
Thanks for this! I was looking on my phone and didn't get that little noti down there. Cheers bro!
Old 07-03-2021, 09:48 AM #5
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
My only recommendation is, do not cheap out on wheel studs or go with an off brand just because it’s in stock now. I’d wait for the ARP’s or find OEM studs that are longer.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
4runner , extended , found , run , studs
Longer extended wheel studs Twisted Sid 3rd gen T4Rs 22 04-12-2020 12:30 PM
Extended wheel studs advisable with Spidertrax? paddlenbike 3rd gen T4Rs 25 03-17-2016 10:56 PM
Help with extended wheel studs - Shank lug nuts MikeT4R 4th Gen T4Rs 0 10-12-2015 04:40 PM
FS: Extended Wheel Studs ryhi For Sale: T4R Items 1 09-20-2012 02:12 AM
Extended Studs Without A Spacer? SCRunner12 3rd gen T4Rs 6 08-23-2011 04:45 PM
