Closed Thread
Old 07-04-2021, 11:17 PM #1
Lewis&Clark Lewis&Clark is offline
Real Name: Dan
Lewis&Clark is on a distinguished road
Real Name: Dan
Strange sound at engine — listen here. Lights flashing on dash too.
At this URL, you can see a video of the sound my 2008 4Runner makes when starting up. Kind of a hum or motor sound.
Dropbox - Video Jul 04, 7 48 15 PM.mov - Simplify your life
This sound goes on for 25-30 seconds and then just stops. But then the check engine light and stability lights are on/solid, and the VSC OFF light is blinking.
Ive had those light issues before and they were just as other threads talk about here a poorly fitting gas cap. But Ive never had this sound before.
Any thoughts?
2008 4Runner V8 Limited ("Lewis"), all factory options.
Old 07-05-2021, 02:05 PM #2
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
If that's the V8 in your sig line, and the sound is coming from the engine compartment, then the first thing I'd suspect is the secondary air injection pump.
Old 07-06-2021, 12:30 PM #3
Real Name: Dan
Real Name: Dan
Thanks. That’s a decent start for me to run with. This is indeed the V8. 2008 Limited.
Is there any connection between a potential secondary air injection pump issue, and the presence of the check engine, VSC, and traction control lights? Or is that more likely a coincidence?
Old 07-06-2021, 02:24 PM #4
Yes, a SAIP failure will trigger the CEL. Any time the CEL is activated for any reason, the truck will disable it's TC and VSC functions.
Around here, all auto parts stores will download the CEL code for you free of charge. It's a good place to start. That, and listening to the SAIP in the engine bay.
Old 07-06-2021, 07:44 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of AuSeeker has much to be proud of
Real Name: Skip
Originally Posted by Lewis&Clark View Post
Thanks. Thats a decent start for me to run with. This is indeed the V8. 2008 Limited.
Read through the topic linked below for more on the SAIP (Secondary Air Injection Pump) failure, also contact @slyfox75 for a possible fix/bypass, he may respond in this topic since I "mentioned" above.
As mentioned finding out what codes have been triggered will help determine what the issue actually is.
Secondary Air Injection Pump Failure on V8's! Important!
2004 Limited V8
AuSeeker is offline
Old 09-06-2021, 08:01 PM #6
Real Name: Dan
Real Name: Dan
Thanks everyone for the help. It was indeed my secondary air injection system. I ended up having to replace the pump, filter, and tubes, but the problem went away when that was done. 1500 miles ago now, so hopefully it'll stay that way...
Closed Thread
engine , i’ve , light , lights , sound
Highlander dash warning lights flashing renau001 All Other Vehicles 5 03-09-2021 01:54 PM
Strange buzzing sound from dash under acceleration..... AlphaQup 4th Gen T4Rs 8 12-28-2020 12:51 AM
Strange engine sound/noise Rob P. 3rd gen T4Rs 0 05-27-2016 02:32 PM
Flashing Dash Lights and Battery Drain tacojeff 3rd gen T4Rs 2 02-07-2015 01:04 AM
Flashing 4x4 lights on dash racefan_67 4th Gen T4Rs 14 02-02-2012 10:59 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
