Old 07-05-2021, 06:19 PM #1
Richrd Richrd is offline
Richrd is on a distinguished road
dealer says I need two new air fuel sensors for $750
Is the AF sensors just another name for an O2 sensor? If not, where would they be located and how hard to change?
thanks
Richrd is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 07:37 PM #2
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
thanks
Rockauto.com , Denso sensor, about $110 each. Wrench is $10. 1000 videos to learn from on youtube
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 10:04 PM #3
Filthy4Runner63's Avatar
Filthy4Runner63 Filthy4Runner63 is offline
Filthy4Runner63 is on a distinguished road
thanks
Yes it's a fancy name for O2. As said above rock auto has good priced denzo. I can confirm they are legit used denzo from rock auto a couple times on my evos. I've never changed one on a 4runner but it's pretty clean cut. I recommend spraying the sensors the night before with PB Blaster, stuff works like magic!
Also if there's room I highly recommend using the deep socket O2 sensor not the angles one with an opening. The one with the opening has stripped a few sensors for me!
Sent from my Pixel 4 XL using Tapatalk
Filthy4Runner63 is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 11:05 PM #4
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Difference between Toyota AF sensors and O2 sensors:
All you need to know about Toyota Oxygen sensors and AF sensors - YouTube
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 11:10 PM #5
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I bought a Denso O2 sensor for my 2004 V8 on Amazon for $38. The O2 sensor socket was another $12.
It was very easy to replace, and it was my first time replacing an O2 sensor. I have no idea why the stealership wanted $750 to replace two. $76 in parts and max $200 labor (I’m being generous).
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 11:13 PM #6
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
thanks
What issues are you having? Is the engine throwing a code?
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 08:19 AM #7
Drcoffee's Avatar
Drcoffee's Avatar
Be careful, buying car parts like sensors on amazon ebay etc. there are no protections against counterfeit parts. Or parts that didnt pass inspection and were rejected. There is a reason they are so cheap.
Old 07-06-2021, 03:40 PM #8
Whamola Whamola is offline
Whamola is on a distinguished road
I pray you don't run into what I did -- the sensor was installed crossthreaded. Took an act of God to get it out, then a trip to a machine shop to borrow a proper tap...4 hours later I had the 10 minute job done.
Whamola is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 05:39 PM #9
ads2539's Avatar
ads2539's Avatar
So far, the O2 sensor has worked fine, and my fault code is gone. I hope it lasts! I try not to buy stuff on Amazon/Ebay from Chinese sellers, and it’s hard to do. I also have 8 spark plugs that I bought on Amazon a few years ago. No problems yet, luckily.
Old 07-06-2021, 05:57 PM #10
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
i stopped at "dealer says"! they may be right, but the dealers aren't called stealers for nothing! i'm helping a relation with a 2000 avalon loss of coolant issue. needs a new water pump. dealer wats to replace the TB pulleys and tensioner (car has 70k). one pulley is $340! i ordered a TB kit off Amazon with high quality pieces (Aisin, Koyo, etc) including all pulleys. total: $165.
be careful, shop things around.
rwh963 is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 06:45 PM #11
I'm trying to fid the af sensor at rock auto, does anyone have the part number?
Old 07-17-2021, 09:50 PM #12
Drcoffee's Avatar
Drcoffee's Avatar
Use only denso. Rockauto.com. There is only 2. upstream and downstream.
change , dealer , hard , located , sensors
Save on Fuel Injectors, Sensors, Spark Plugs & More at RockAuto! RockAuto Rockauto 0 06-17-2020 12:27 PM
4th Gen 2005 Toyota 4Runner exhaust Air / Fuel oxygen Ratio Sensors Spichak For Sale: T4R Items 0 06-06-2014 06:17 PM
4th Gen 2005 Toyota 4Runner exhaust Air / Fuel oxygen Ratio Sensors Spichak For Sale: T4R Items 0 05-24-2014 10:42 PM
4th Gen 2005 Toyota 4Runner exhaust Air / Fuel oxygen Ratio Sensors Spichak For Sale: T4R Items 0 05-05-2014 09:19 PM
Dealer whammie on yaw tire sensors JBKox 4th Gen T4Rs 4 07-09-2007 09:05 PM
