Old 07-06-2021, 02:53 PM #1
rodsrunner rodsrunner is offline
rodsrunner is on a distinguished road
Oil filter re-located
I have a 2004 SR5 4.0 with the oil filter located in a very accessible position on top, why did they relocate below the motor and now the skid plate has to be removed?
rodsrunner is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 03:36 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
They didn't want you to get bored! There's a discussion about it somewhere on here, it was necessary because of some changes that had to be made that wouldn't allow it to remain where it is on yours.
Old 07-07-2021, 10:30 PM #3
I looked but could not find any info, yes it was very nice.
Old 07-15-2021, 12:33 PM #4
Does anyone know why?
Old 07-15-2021, 08:01 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Because engineers are a$holes?
Old 07-16-2021, 02:54 PM #6
swampdodo swampdodo is offline
swampdodo has a spectacular aura about swampdodo has a spectacular aura about
Because they wanted you to experience what it was like to change the oil on a 4th Gen V8...without actually having a V8...
swampdodo is offline   Reply With QuoteReply With Quote
Old 07-16-2021, 04:19 PM #7
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Here’s one explanation of why the oil filter location was moved:
https://www.toyota-4runner.org/3258223-post82.html
And another:
https://www.toyota-4runner.org/3259807-post89.html
Old 07-17-2021, 09:30 AM #8
Thumbs up
Thanks, now that makes sense.
Old 07-17-2021, 10:23 AM #9
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
The new RAV4 has a canister filter and dual VVT, doesn't it?
Old Tanker is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 12:22 PM #10
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
How relieved am I that I have a single VVTI 2007 V6 - I don't think I would have got this filter off if it wasn't accessible on the top!!
It took over an hour and I tried every trick in the book...I kept going thinking it was utterly futile and eventually it moved. I had to use the strap for a whole turn before I could do it by hand
SurferUK is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 02:45 PM #11
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Most oil changes at dealership[s and private garages are done by the least experienced mechanics because it's not all that hard to do, I have seen many times a beginner mechanic use the oil filter wrench to tighten the oil filter instead of tightening it by hand as you're suppose to do, the reason to do it by hand is because over time and heat cycles the oil filter will become tighter because the rubber gasket tends to swell and it will be difficult to remove as you discovered.
I have also seen most beginner DYIers do the same thing as well when tightening the filter.
So there's a good reason most oil filters come with instructions to tighten the filter by hand until the gasket comes in contact and then tighten it another 1/4 turn and then check for leaks and then again after driving it a bit, if there's any leakage then you can tighten a bit more.
When I was still doing work professionally as a mechanic there were many filters I had to totally destroyed to get them off.
2004 Limited V8
Old 07-17-2021, 03:14 PM #12
SurferUK's Avatar
SurferUK's Avatar
Yes mate, I have struggled with occasional tight filter on new (To me) vehicles I have bought but this was another level!
I was still feeling a sense of relief hours later, as I could not afford to destroy the filter as one way or another I needed to start the engine to move the vehicle back onto the driveway (On a hill)
You can see how close I got!
Old 07-17-2021, 03:23 PM #13
Real Name: Skip
Real Name: Skip
Did you not have a new replacement filter, I'm confused, why were you removing the old filter???
2004 Limited V8
Old 07-17-2021, 05:00 PM #14
SurferUK's Avatar
SurferUK's Avatar
Yes but if I broke the old filter and could not remove it, I then had no way of starting the engine (Without spraying oil everywhere) to get it back onto my driveway
Old 07-17-2021, 06:28 PM #15
Real Name: Skip
Real Name: Skip
Once all the sheet metal of the filter is gone and only the threaded mounting flange left it is a much stronger/solid material/steel and also the holes in it makes it much easier to remove.
2004 Limited V8
filter , motor , oil , plate , skid
FS: V6 4runner/Tacoma/Tundra engine air filter + cabin air filter $15 - North NJ jsun_2k For Sale: T4R Items 5 08-15-2019 12:53 PM
5VZFE Bosch Premium Oil Filter Parts Compatibility (and using an Oversized filter) nobb 3rd gen T4Rs 6 11-20-2013 03:07 AM
Where is the hydrocarbon filter located? eskimochaos 4th Gen T4Rs 11 07-26-2009 11:38 AM
Where is the fuel filter located on a 2002 4Runner? MxChase Maintenance/Detailing 2 12-30-2007 07:53 PM
where is air filter located bnob99 Maintenance/Detailing 2 09-22-2004 06:26 PM
