Originally Posted by SurferUK
How relieved am I that I have a single VVTI 2007 V6 - I don't think I would have got this filter off if it wasn't accessible on the top!!
It took over an hour and I tried every trick in the book...I kept going thinking it was utterly futile and eventually it moved. I had to use the strap for a whole turn before I could do it by hand
Most oil changes at dealership[s and private garages are done by the least experienced mechanics because it's not all that hard to do, I have seen many times a beginner mechanic use the oil filter wrench to tighten the oil filter instead of tightening it by hand as you're suppose to do, the reason to do it by hand is because over time and heat cycles the oil filter will become tighter because the rubber gasket tends to swell and it will be difficult to remove as you discovered.
I have also seen most beginner DYIers do the same thing as well when tightening the filter.
So there's a good reason most oil filters come with instructions to tighten the filter by hand until the gasket comes in contact and then tighten it another 1/4 turn and then check for leaks and then again after driving it a bit, if there's any leakage then you can tighten a bit more.
When I was still doing work professionally as a mechanic there were many filters I had to totally destroyed to get them off.
