Old 07-08-2021, 12:59 PM #1
Qnbrew88 Qnbrew88 is offline
Qnbrew88 is on a distinguished road
Power Steering fluid low
Good morning all,
I was searching for this topic but couldn't find anything.
I have a 2004 V6 SR5 with 129K miles.
Yesterday i noticed my power steering fluid reservoir is about a quarter inch below the minimum line on cold.
I followed the hoses but could not see any leaks, power steering pump looks dry too,. and the floor was also dry.
My question, is do you think there's a slow leak? or is it normal to lose a little bit over time? And if there's a slow leak, where should i be looking at?
Also, could recommed a power steering fluid brand?
Manual says Dexron 2 or 3 but i only see 4's at my local store.
Thanks!
Qnbrew88 is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 03:06 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by Qnbrew88 View Post
Good morning all,
Thanks!
Check the boots for wetness, most leaks will probably occur on the outputs of the rack.
I'd go ahead and flush the system, then fill and monitor for now. I used Valvoline maxlife atf, since it's rated for just about every ATF type under the sun
Writeup for the flush: DIY: Power Steering Flush (4th gen specific)
y=mx+b is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 03:39 PM #3
Thank you. I'll do that.
Old 07-08-2021, 07:25 PM #4
Urbanite Urbanite is offline
Urbanite is on a distinguished road
I'd also remove & clean the reservoir while you're at it, it makes a big difference in the long run!
Urbanite is offline   Reply With QuoteReply With Quote
dry , fluid , power , slow , steering
Power steering fluid level low. Do I use ATF or power steering fluid? 4flyer 3rd gen T4Rs 63 02-24-2020 05:07 AM
power steering fluid? yeauxkna_at Maintenance/Detailing 12 06-24-2017 12:53 PM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
Low Power Steering Fluid sct6239 4th Gen T4Rs 5 02-02-2012 03:50 PM
Power steering fluid dmanla Maintenance/Detailing 2 08-22-2008 05:39 AM
