Old 07-10-2021, 11:39 AM #16
Toystory2's Avatar
Toystory2 Toystory2 is offline
Toystory2 will become famous soon enough
Toystory2's Avatar
Originally Posted by Flesh Eater View Post
Just remember, none of us just magically knew how to do this stuff. I learned via forums and YouTube and have honed my skills since my first off road build almost 12 years ago. I did not grow up turning wrenches.
Go to Tekton’s website and get their 1/4”, 3/8”, and 1/2” drive metric sets and you can fix anything on this Toyota with those and a big hammer.
That’s a good point. I learned what I know now by buying an 88 Runner that had a lot of issues. It was my daily driver so I had no choice to but to fix it or stay home. Thanks for the recommendation on tools!
Toystory2 is offline   Reply With QuoteReply With Quote
Old 07-10-2021, 11:45 AM #17
Toystory2's Avatar
Toystory2's Avatar
Originally Posted by GeoFlory View Post
As you point out, the V6 can get up and go. The V8 is rated for 260 hp and 306 lb-ft torque compared to the V6's 236 hp and 266 lb-ft torque, so that is 10% more hp and 15% more torque. It is a relatively small V8 at 4.7 L (285 in3), and not intended as a powerhouse, but it is a bit peppier than the V6 (I drove the '98 and '09 V6s for 14 years). I originally shied away from the V8 because I was afraid the V8 and full-time 4WD would wreak havoc on gas mileage; however, after driving the V8 home for 340 miles on the expressway, I filled it up and got 20.5 mpg which is about the same as the V6 ever got. What I have found so far is that I really like the full-time 4WD on the V8; I find I can take off from a light with rapid acceleration and not break the tires loose in the rain; with the V6's multi-mode 4WD, I often found my back tires spinning in the rain or on gravel and dirt before I manually engaged 4WD. To me, the big thing is the Class IV, weight-distributing trailer hitch (standard with V8) because I plan on towing a 6000 to 7000 lb trailer.
I also have the original XREAS suspension which I wanted to try. So far, it seems firmer and steadier than the regular suspension going over railroad tracks. I am a believer in what I have heard called the military philosophy: "If you can't test it, it's broken.", so I am wondering how to really test it. I hear a lot of people remove the XREAS, but I intend to maintain it always.
I finished checking out my brakes. The front indeed has the 338 mm rotors with the 13WH calipers; the rotors look rather impressive at 13.3 inches OD, and 1 1/8 inches thick. I measured the thickness because it just struck me that they seemed thicker than others; the rear rotors are 12.3 inches OD and 3/4 inch thick.
I was also concerned about gas and extra maintenance having full time 4wd, but I’m sure they wouldn’t have built it that way if it caused problems. But man it’s sounding better and better lol I may have to start looking. I’d probably go with a limited too if I change. Don’t know if I can justify trading this awesome one I already have tho. Glad your brakes and rotors are looking good!
Old 07-10-2021, 01:17 PM #18
Toystory2's Avatar
Toystory2's Avatar
Originally Posted by meltdowner View Post
Grease the zerks!!!!!!!! Change oil and tranny fluid. A mechanic will probably do it all cheap.
Post photos of the frame.
It’s definitely got more rust than I realized : (
Most of it still seems solid, but there are a few soft spots. How horrible is this?
Why did I wait so long to get a 4th gen??-eac97fec-fc1a-4967-a4ae-fe9448308464-jpg  Why did I wait so long to get a 4th gen??-30d16f50-4421-4176-8062-3d851c2da768-jpg  Why did I wait so long to get a 4th gen??-a81ae540-723b-4f34-8451-4494fb71fd42-jpg  Why did I wait so long to get a 4th gen??-61928341-ecad-4d9c-93ef-57931d87cb4b-jpg
Old 07-10-2021, 08:06 PM #19
CadRunner CadRunner is offline
CadRunner is on a distinguished road
I'm Currently in the process of trading in my 2017 Tacoma OR (191,000KM) for a 2004 V8 Sport Edition (143,000 KM). Its good to hear that you are liking the ride a lot more!!
I would probably take It to a shop that deals with restoration's or a reputable body shop. They may be able to fix the soft spots on the frame with out too much issue before it gets worse? If they can fix it with out too much issue and the rest of the vehicle is in good shape then it may be worth the repair?
CadRunner is offline   Reply With QuoteReply With Quote
Old 07-10-2021, 08:48 PM #20
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If you find on a visual inspection that the frame seems to have 15% to 20% bad rust issues/spots it more than likely has twice to 3 times that much rust because many times the rust starts or is on the insides of the frame rails where you can't see it until it rust through to the outside of the frame!
Tap on all the good areas of the frame, every square inch with a hammer, if it doesn't sound solid then that spot has bad rust on the inside of the frame which will soon come through the frame.
2004 Limited V8
Old 07-10-2021, 08:55 PM #21
Toystory2's Avatar
Toystory2's Avatar
Yea for real, i am very impressed with how it runs and rides. I’m gonna have someone check it out and hope that’s not too far gone. Some folks on Reddit said it’s mostly surface rust…I sure hope so
Old 07-10-2021, 08:57 PM #22
Toystory2's Avatar
Toystory2's Avatar
It’s hard to say the percentage as it is pretty spotty on the frame. I knocked around with my hand and most of it felt or sounded solid. It’s flaking quite a bit so I’m wondering if this hasn’t been treated with something before I bought it. Either way, not what I wanted to see after just buying it : (
Old 07-10-2021, 09:18 PM #23
Real Name: Skip
Real Name: Skip
The 15% to 20% I referenced was for obvious severe rust spots where the metal is actually gone from rust, not surface rust, if all one finds is surface rust, it's most likely the same on the inside BUT surface rust is most always not an issue on any frame or any structural metal.
2004 Limited V8
Old 07-10-2021, 10:49 PM #24
Toystory2's Avatar
Toystory2's Avatar
Im gonna try to get it in somewhere next week and get a good evaluation on it. It appears to me mostly surface rust with some flaking. There’s a couple of smaller spots on the frame that are questionable. Is there anything I can do immediately (as in tomorrow) to help before I get it into a shop?
Old 07-11-2021, 07:23 AM #25
Real Name: Skip
Real Name: Skip
You can remove as much of the worst flaking as you can by chipping, scraping and wire brushing, which will help to see how deep the rust goes in those areas.
2004 Limited V8
find , listed , maintenance-wise , things , wasn’t
How long to wait until first detail? newbian Maintenance/Detailing 9 06-07-2015 06:23 PM
Why did I wait so long to get one off these?! Freb_mc New Members 7 05-13-2013 08:55 PM
Long wait... Craig8d8 5th gen T4Rs 1 04-20-2012 03:48 PM
How long should I wait to buy? skibama 4th Gen T4Rs 9 08-01-2005 07:38 PM
