Old 09-22-2021, 08:56 AM #16
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Project is completed, rack is bled and vehicle is ready for an alignment this morning. I took this opportunity to install 555 Senkei sway bar end links as the boots on the current (non OEM) end links were shot after couple of years but there were no play.
I also took this opportunity to replace every single hose on the PS system and this was a royal PITA. Even though they weren't leaking, they were rock hard. There is a total of seven hoses that were replaced. The hose shop cut off part of the OEM hard pipes and brazed them on to USA made hyd fittings with flare ends. The total cost for this was $120 and bulk off that was the brazing work. If you price out these hoses from Toyota, the price would've been astronomical, approaching $500, with the high pressure hose being the most expensive.
Just a quick note/tip: be sure to label every single hose like I did and give the hose shop as you see it in the pics. I asked them to return the old hoses, labels, and pinch clamps back to me so I knew where everything went and how long was each OEM hose.
I now understand why Toyota went with hard pipes behind the front bumper from the pass side to the drive side, they act as a cooler. They could've easily followed the front cross member to do this but the air flow would've been reduced.
Couple of observations on the newly rebuilt rack from the Rackdoctor.com. -
-My rebuilt rack was missing the large washer that is bent to prevent the inner tie rod from spinning. Probably not a big deal as the inner tie rod isn't going spin by itself. I re-used the one from my current rack.
-the rubber dust boot that keeps the dirt out of the rack input splined shaft didn't make it back with my rebuilt rack. I re-used the one from my current rack.
-they used a CV clamp on the steering boot on the large end but used a zip tie on the small end. Again, they could've transferred the OEM pinch clamp that was present when they received my rack for a rebuilt. I re-used the ones from my current rack.
I'm sorry about the sideways pic as it doesn't seem to matter which was I turn it then save it on my PC.
Power steering rack removal '03 4runner V8-20210921_172551-jpg  Power steering rack removal '03 4runner V8-20210921_084538-jpg  Power steering rack removal '03 4runner V8-20210921_083938-jpg  Power steering rack removal '03 4runner V8-20210921_090027-jpg  Power steering rack removal '03 4runner V8-20210921_090034-jpg  Power steering rack removal '03 4runner V8-20210921_101810-jpg  Power steering rack removal '03 4runner V8-20210921_172103-jpg
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 09:22 AM #17
more pics. Notice the mounting bolt is now upside down, this makes it super easy to install then torque to spec. Also notice the serration marks on the nut. This is why you shouldn't turn the nut, ONLY the bolt.
Power steering rack removal '03 4runner V8-20210921_074922-jpg  Power steering rack removal '03 4runner V8-20210921_083524-jpg  Power steering rack removal '03 4runner V8-20210921_083546-jpg
power , rack , read , removal , steering
4th Gen 4Runner 2003-2009 Power Steering Rack Replacement How-to / DIY HokieRunner 4th Gen T4Rs 29 01-27-2024 02:04 AM
Power steering rack leak/ drive with out power steering ryanrmurray02 3rd gen T4Rs 6 02-06-2021 04:34 PM
Power Steering Rack Removal: How do I get the pressure lines off?? nobb 3rd gen T4Rs 27 03-08-2019 12:05 PM
3VZE Power Steering Belt Removal astynx Classic T4Rs 7 02-01-2016 04:28 PM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
