Old 09-18-2021, 06:07 PM #1
Toystory2's Avatar
Toystory2 Toystory2 is offline
Toystory2 will become famous soon enough
Toystory2's Avatar
Still squeaking after suspension refresh
My 2007 4WD had been clunking and squeaking when I would roll over a bump or hit a dip in the road.
But now that I have replaced both front upper and lower control arms, and front/rear shocks, it is still clunking!
Any idea what to check for next??
Only thing I can think of is sway bar bushings.
Toystory2 is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 06:23 PM #2
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
I mean you have both sway bars, 4 end links, tie rods, pan hard bar, and 4 links still to verify at least.
On my icon setup I just found out that the rear springs are squeaking on the upper rubber bump stop, been driving me nuts, I thought it was my custom links and heim joints but nope..
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 06:40 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
Definitely look/replace the sway bar bushings where it mounts to the frame. Any looseness there will give an odd thunk with certain bumps. When the control arms were installed were the frame bolts tightened with depressed shocks? They should be tightened when the car is at it's normal resting position.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 09-18-2021, 07:02 PM #4
Toystory2's Avatar
Toystory2's Avatar
Thanks, it actually is more of a thunk sound… and it’s not every bump, but more of the big ones.
Come to think of it, we may have tightened the arms in without load on the suspension….
If that’s the case, how would you fix that? Undo and retighten under load?
Old 09-18-2021, 07:19 PM #5
Toystory2's Avatar
Toystory2's Avatar
Much appreciated. I’m a novice at this stuff, so not real sure what all could produce such a noise lol
I believe I have at least isolated the thunk to the front … probably driver side
Old 09-18-2021, 07:43 PM #6
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
The sway bar is a well known and documented noisy point on these trucks, specifically the front..
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 09:17 PM #7
Toystory2's Avatar
Toystory2's Avatar
Is typically the bushings or can it be the bar itself making the clunk?
Old 09-18-2021, 10:02 PM #8
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
If you hit a driveway approach straight on, and both wheels move together and there's no clunk, it's very likely the sway bar.
If it clunks when one wheel goes up the approach first (articulating one wheel independently) and it clunks, it's absolutely the sway bar.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 10:04 PM #9
Toystory2's Avatar
Toystory2's Avatar
Interesting. I’ll have to pay close attention to that. From what I have noticed, it seems to clunk more on the one wheel approach l. Definitely seems to favor the driver side.
Old 09-18-2021, 11:10 PM #10
Toystory2's Avatar
Toystory2's Avatar
Found some pics of the sway bar I took a while back. I wasn’t paying too much attention at the time, but it’s looking pretty rough. Even seeing some cracks on one side. I guess I need to start looking for a new one. I just ordered some Energy suspension bushings too.
Old 09-19-2021, 11:18 AM #11
the "cracks" are just the paint coating, not the bar itself. you most likely dont need a new bar, just install the new bushings & see if they fix or improve the clunk & go from there.
Old 09-19-2021, 12:21 PM #12
Its the bushings and endlinks..
2005 4Runner SE V8
Old 09-19-2021, 01:07 PM #13
Toystory2's Avatar
Toystory2's Avatar
That’s good news, although I may just give it some kind of rustoleum paint while I’m at it.
Old 09-19-2021, 02:28 PM #14
If the bar is actually cracked, it will break at some point very soon. So I wouldn't worry about replacing it, it'll let you know.
The clunk is the steel bar being able to move back and forth. Normally, it's held rigidly and only able to rotate as the suspension moves up and down... doing it's job of being a linear spring. Once some play is available in the bushings it bangs around in there.
There's a huge amount of force involved in the sway bar system. I generally kill a set every couple of years. Speaking of which, mine need replaced too.
2005 V8 Limited
Old 09-19-2021, 04:58 PM #15
Toystory2's Avatar
Toystory2's Avatar
That’s interesting. I didn’t suspect the sway bar initially because I didn’t think it would generate that loud of a clank. I just ordered new bushings, so I’ll take it off and give it a good check when I put those on. If it still squeaks, I guess the sway bar links are next.
check , clunking , front/rear , shocks , squeaking
‘14 TE hit 100k mi - Suspension Refresh? Throwback 5th gen T4Rs 5 03-22-2021 03:11 PM
All original suspension need refresh! T4R416 4th Gen T4Rs 6 07-09-2020 08:51 PM
Suspension refresh kit? dcTR4 4th Gen T4Rs 6 11-28-2018 02:22 PM
suspension refresh: more confused than ever mhenks05 4th Gen T4Rs 10 01-30-2018 09:08 AM
Suspension refresh on 05 SR5 ThatSickRip 4th Gen T4Rs 7 12-21-2017 09:06 PM
