It doesn't do it if I coast and no clunk on braking - only on accelaration. Often happened turning so I thought it was CV. Had both CV axles replaced ( boots were hashed when I got it in Feb.) Tested in 4Lo and it added clunking in reverse. Got it home fine and searched here. Sounded lije maybe pinion in front diff?
But it's a clunk not gear grinding noise. I greased every zerc on the driveline. Slip joint didn't ooze, it expanded then contracted while taking grease. Driveline is a little loose in the back, but that's not where the clunk is coming from. I checked front diff fluid was full. I guess I could drain and look for metal. Got my husband to let me drag him around alongside the truck (super slow) and he thinks it's coming from the transfer case.
Sent from my SM-S911U using Tapatalk
