02-06-2014, 09:51 PM
KNOCKING noise over bumps???
05 sport v8 4x4 240K. knocking in front area going into driveway or driving down slightly irregular paved road (notice under 35mph). Not driveshaft or pads. Had master cert Toyota tech spend an hour plus with assistant and can't find it. Said he thought it was flex connection in front of muffler. Had flex and muffler replaced...knock still there. My son and I thing RF is loudest but hear something on R mid to rear (wifes thinks noise in R side mid/rear). Can't hear nosie outside truck with assistant. New Xreas shocks before I picked up truck. Any ideas will be greatly appreciated. Thx in advance
My 4Runner-05 Sport V8-360K+ miles
02-06-2014, 11:44 PM
Do you notice it while turning the wheel?
Is it one knock or multiple?
2018 4Runner, SR5 Premium, Silver
2015 4Runner, Limited, White
2015 Lexus RC F, White
2010 Lexus IS350C, USB
02-06-2014, 11:52 PM
Clicking from caliper, or heatshield loose noise , or trannie rumble or bushing squeaking ???
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
02-07-2014, 09:40 AM
Possibly worn sway bar bushings. They will clunk when hitting bumps.
02-07-2014, 09:51 AM
Not a squeak or a rattle, not pad clips. Knocking and repititive. 3 bumps 3 knocks. I have had my toyota tech ck everything as well i have been under checking everything. It is tight and appears good. I am going to check body to frame mounts this weekend...maybe not in suspension or steering???? If I drive down a slightly bumpy road it just knocks multiple times. It's like a pop or knock.
02-07-2014, 09:53 AM
turning dose not make it knock/pop unless you add a bump ie driveway entrance.
02-07-2014, 10:00 AM
This. Especially after 240k it will be worthwhile.
2006 SR5
2007 Porsche Cayman
02-07-2014, 10:25 AM
This sounds like the same problem i have. Ive replaced all sway bar links and bushings. I like to find the problem but everything seems tight and in proper working order under the truck, im clueless. I havent checked body mounts yet. 2005 v6 130k miles.
02-07-2014, 10:54 AM
This weekend I will be all over my 4runner, hopefully find something! I will keep everyone updated. Eventually I will find the issue. It's funny cuz you can n ot hear it when standing by the front and going into driveway...only in the cab...plus frt end appears solid. I am thinking steering rack, inner tie rod ends, body mounts???? Some mentioned front bumper mounts in a thread?? I'm checking all that....
02-07-2014, 12:39 PM
I'm having the same problem from right front wheel area. Doesn't happen on the left side. Notice it going over small bumps. just a popping sound that is driving me nuts. I ordered sway bar bushings and a new sway bar link for that side. Lets keep this post going because I think there are more that have this going on.
06 limited V8 w. 129k
2006 Limited V8 FJ coils all around - Bilstein 5100's set at 1.75 - Icon Rear 2.0 - Daystar 1.5 rear spacer - Customish' end links - - LED interior upgrade- GROM audio blutooth unit- weathertech floormats -Spidertraxx 1.25" Wheel Spacers Michelin LTX AT/2 275/65/18
02-09-2014, 11:49 AM
Stopped by another shop that had a Lexus master cert tech, actually was part of lexus R&D. Diagnosed as R inner tie rod end...well 230 plus later still has knock and steering wheel crooked! Said he would put his mechanic easrs on and keep charging me TS time. Won't be back other than to have him correct the off center steering wheel. Be back Monday to have them sq away. Had new Xreas installed 6/12....front and rear...almost sounds like all 4 shocks are banging knocking. RF is the loudest. Ready to throw some Bilstiens height adjustables on the truck...Ive bot over $400 into theis noise right now... I found all 4 Bilstiens for $360.
02-09-2014, 01:18 PM
Sounds like it could be the right front strut bearing(bushing) at the top I know I've seen some posts here or on 120 about this. I have the exact same sound and it drives me nut's just haven't taken it in to my suspension place to get them to check it out..
02-09-2014, 01:35 PM
I don't think it's your suspension. I have billies up front and noise still persists. I'm hoping sway bar link fixes. Every thread I've seen on this, no one has diagnosed and it always seems to be right front.
02-09-2014, 01:55 PM
Real Name: Tony
Real Name: Tony
Mine sound like that, and I know they are blown. Fluid leaking out of the lines. I got you beat on Bilstein price though. Check these guys out. Toyota 4-Runner Front Bilstein 5100 Ride Height Adjustable Shocks 03-2009 w/ Optional Rear Shocks Just ordered mine, will be here in a few days.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
02-09-2014, 02:00 PM
Real Name: Derek
Real Name: Derek
Pull the front sway bar off, drive, noise still there? Not the sway bar.
I had two front end mystery noises.
The first was the headlight assembly hitting the fender, top edge at the pointy part. Sandpaper plastic of headlight to fix.
The other noise was the lower front shock mount to lower a-arm.
The shock eye was hitting the a-arm.
Good luck!
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
