Originally Posted by Toystory2
Not 3 weeks after buying a 2007 SR5, I have taken it to a mechanic to have some repairs estimated.
I am somewhat mechanically inclined, is it reasonable that I can do any of this myself?
This is what they quoted me:
With these prices, I'm going to side with they're probably gouging you and most of the services probably not needed. For example, at 210-230k miles, all of my ball joints, bushings, and all suspension was in worn but still decent condition and passed inspection without issue. I only started replacing stuff when my cam bolts seized and that snowballed into suspension stuff for offroading. But for regular road use, everything was fine.
Upper and Lower Control Arms, Shocks/Struts, and alignment: $3,800
I've got a writeup on rebuilding the LCAs if you take that route, but it is a decent amount of work. The writeup covers everything from removal of arms by sawzall and all parts/tools needed, so applicable to the straight LCA replacement option too
Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures)
I'm working on writeup for suspension and UCA install, not sure ETA on that, but I already have lots of pictures and info from my replacement
These are price guestimates off the top of my head for just part costs if you want to purchase yourself. Don't hold me to these, just throwing them out to give you an idea of part costs:
LCAs
OEM (McGeorge Online usually best prices, but shop around): $700-900
SuperPro Poly bushing LCA: $670
1A Auto (Cheapies to get by): $200
Time: 0.5-1 day to replace at home
Alignment HW
OEM: $150
MOOG: $50 maybe (These are trash though, get OEM)
Time: Included with LCA time
UCAs:
OEM: Not sure, but I'll look
JBA Factory Replacement or High Caster (For lifted): $450ish
SPC Adjustable (helpful for custom alignment after lift and larger tires): $630
Apache Offroad (For lifted): $550
5th gen takeoffs (lot of 5th gen guys take them off with low mileage and lift right away): $50-100
Suspension:
KYB (Stock Replacement): $300ish I think
Dobinsons (Lift or I believe there are some stock replacement): $800-1000
5th gen takeoffs (lot of 5th gen guys take them off with low mileage and lift right away): $100-200
Time: 2-3 days. For me I needed to replace flex brake lines for longer rear shocks which snowballed into replacing hard lines all the way back so it took 4 days
Alignement
Firestone Lifetime: $200
Replace rusted trans cooler lines: $1,000
This one I would recommend taking to a shop if you're still learning car mechanics. I'd even check with the dealer on their pricing, since $1000 is a lot of cash, even a stealership might be cheaper. Also look for an independent Toyota/Lexus mechanic and get their opinion
New fuel tank straps: $600
This job isn't too terrible, don't even need to drop the tank. I disagree with the other commenter, don't do the fuel pump. You are not halfway to its replacement with just the straps. Heavily apply penetrating fluid (I like 50/50 acetone/ATF) to all the bolts and use an impact. I didn't break any and mine were crusty AF
Fuel Tank Strap Replacement Tutorial (60+ Pictures)
Part Cost: $50-75
Time: 1-2 days
New skid plates: $400 each
These aren't really critical for your vehicle to run/be safe, definitely not needed. Stock skids do provide minimal protection against road debris and such, so they are helpful in some regards. Off road skid plates of course provide more protection
The cheapest one I can think of its the LFD Offroad skid for $180 + $50 shipping (or pickup in NC)
Time to to straight replace: 1hr
If broken bolts: 1-2 days
On the broken bolts note, I would not bother with screw extractors or drill and retap. This is what I did and wasted a lot of time. The retapped holes eventually loosened up some pieces of broken bolt and the new hole isn't perfectly in the center, so they don't hole. Either weld a washer then a nut onto the bolt stump or drill out completely and rivnut
Rusted frame repair At least $1,000
This one I would also look into taking to a professional to get it taken care of right. As mentioned, they'll cut all the rusty section out, then weld in good metal.
