Old 07-22-2021, 01:51 AM #1
bzettler83 bzettler83 is offline
bzettler83 is on a distinguished road
Heavy Vibration From Rear Of Vehicle
05 T4R - 185k miles - V8 -
My 4runner has had a fairly noticeable vibration from the rear of the vehicle for sometime now and I am finally to a point where I want to correct it. It is noticeable above 60MPH and is to the point where the passenger seat shakes fairly bad. Much MUCH more than you would consider normal.
-Removed the rear drive shaft and drove it. Vibration still there.
-Balanced tires, and rotated as well, no change. In fact rear tires are NEW.
-Removed wheel spacers, no change.
What else should I be looking at? Could it be a bearing, bad shock / shocks? I have Bilstein's and they are fairly new so I am ruling that out at least for now.
Trying to ID this myself where possible. Worst case I will bring it to a mechanic.
2005 Toyota 4Runner Sport 4WD - V8 - Toy Tech Boss 3" Lift - 1.25 body lift - 40 inch LED Light bar mounted to roof rack - HID Lights - K&N CAI - Cat Back Exhaust - 285/70/17 BFG KM2 - Air Lift 1000 Rear Air Bag Set Up - Diff Drop Kit - Total Choas UCA's, Total Chaos Spindle Gussets, Zip Locker with ARB Compressor, Pioneer AVIC Z150bh w/ back up camera, More to come.
bzettler83 is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 11:51 PM #2
Rocket3004 Rocket3004 is offline
Rocket3004 is on a distinguished road
Any noise or just vibration? Does it change when turning left or right?
Rocket3004 is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 10:24 AM #3
Burt Burt is offline
Burt is on a distinguished road
Check the pinion bearing.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 03:32 PM #4
Runnin on E Runnin on E is offline
Runnin on E is on a distinguished road
Vibration
How about changing the differential oil and looking for metal in the oil (MIO) first. Then rear wheel bearings.
Runnin on E is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 04:25 PM #5
Flesh Eater Flesh Eater is offline
Flesh Eater is on a distinguished road
Lots of rear vibrations posts lately.
Check the pinion for play.
Check wheel bearings for play, turn them to listen for noise.
Check control arm bushings.
Check track bar bushings.
Lots of stuff back there. If no clicking or noise when making sharp turns Id say your rear diff is good.
When was new fluid done in the rear diff or transfer case?
2008 SR5 4Runner V6 4WD
Flesh Eater is offline   Reply With QuoteReply With Quote
change , fairly , point , rear , vibration
Heavy Vibration From Rear Of Vehicle bzettler83 5th gen T4Rs 14 07-25-2021 05:42 AM
HEAVY vibration in 4x4. cccolin 3rd gen T4Rs 1 10-10-2019 01:26 PM
Toytec Boss - Vibration Diagnosis - Pic Heavy sport05 3rd gen T4Rs 42 08-27-2015 10:55 PM
Bad vibration under heavy acceleration? akbass907 3rd gen T4Rs 3 01-27-2014 06:31 PM
Heavy vibration at idle fluffeh 3rd gen T4Rs 7 10-23-2012 12:49 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
