Old 07-22-2021, 01:38 PM #1
chrisbagnell's Avatar
chrisbagnell chrisbagnell is offline
Real Name: Chris
chrisbagnell will become famous soon enough
Real Name: Chris
POR-15 isn't going to fix this one... need some advice
my rear crossmember that supports the bumper and towing capacity, is not looking so pretty. It's been missing the left corner for a few years but I wanted to POR-15 this and I don't feel comfortable putting it all back together knowing it looks like this swiss cheese.. Looking for some help/advice.
Having a hard time finding parts, everything is easy to switch except the cross member which needs welding. Replacing the crossmember and not just welding plates on would be ideal as its rusty all the way through. This is the worst part on the frame.
If anyone has part numbers or knows where to get this stuff that would be appreciated.
Before Hammer
POR-15 isn't going to fix this one... need some advicePOR-15 isn't going to fix this one... need some advicePOR-15 isn't going to fix this one... need some advice
After Hammer
I cannot find the part # for the piece that holds the Door Lock Striker, It comes off and its what the door lock striker bolts into.
Already have the following in the cart, since its rusty I might as well replace it.
Bracket, Rear Bumper Side Mounting, LH #52185-60090
Bracket, Rear Bumper Side Mounting, RH #52185-60090
I would assume I need both side gussets,
Gusset, Frame Rear Crossmember, Rh 51391-35090
Gusset, Frame Rear Crossmember, Lh 51392-35080
And the Rear crossmember
Crossmember Sub-Assy, Frame, Rear 51209-35210 Listed for $422 new, I need to find it cheaper, if anyone has any leads please let me know
2004 Sport Edition v6 4wd, 180k+ miles
My Build Thread: CBR's Build Thread
My Write-ups: How to Manually Release Rear Hatch with Pictures
chrisbagnell is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 03:54 PM #2
Piggity Piggity is offline
Piggity will become famous soon enough
I'd go on car-part.com and find a 4Runner in a non-rust belt state. Get them to cut the whole rear crossmember off (just the steel) and ship it to you. Then get a local welder to cut yours off and weld the new rust free crossmember back on. You're probably looking at less money than all of the new parts from the stealership.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 03:54 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
Dang, that is substantial. By the time it's cut back to weldable metal it will be quite large. My holes in that area were way smaller so I cut back the metal and welded in plates, I have a thread on it here. Before you do any more I suggest you check the rest of the frame closely. Check the bottom side of the frame under where your feet are when driving, the area the fuel tank straps bolt to and the front crossmember where the tow points are. You may find there's more cancer than you thought.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 07-22-2021, 04:02 PM #4
Real Name: Skip
Real Name: Skip
Before Hammer
After Hammer
I couldn't find the hatch latch piece you're looking for..but the rear cross member now has a new part number and it's way less than the price you posted, you may want to check the other pieces you posted at McGeorge Toyota to see if they could be cheaper as well, here a link to the rear cross member.
2003-2009 Toyota 4Runner Cross-Member 51209-35211 | Toyota Parts
To check the price of the other pieces just search the part numbers for the quickest results.
2004 Limited V8
Old 07-22-2021, 05:06 PM #5
Real Name: Chris
Real Name: Chris
Thanks for the advice. The rest of the frame is in great condition, my thought is that the drain holes got covered and it just ate away at that crossmember. Do you have a link to your repair? I was going to search for it but you have a lot of posts..
Thank you so much! I was looking at toyotapartsdeal.com.. I'm going to look for a used part like Piggity suggested but if I cant find one in good enough condition ill get it from mcgeorge.
Old 07-22-2021, 05:57 PM #6
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Due to the large number of folks looking for complete rust free 4Runner frames, I kind of doubt anybody is going to be willing to screw a good one up by cutting off a portion of it to sell you.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 06:58 PM #7
MikeinNH67's Avatar
MikeinNH67's Avatar
It took some digging but post 18 on this thread shows a couple pics. Sorry the pics aren't better. After welding it, all got covered with SEM Rusttrap and the frame has been oiled multiple times since. I still have a rust hole I need to repair in the feet area.
Who had their 4runner frame replaced?
Well that would depend, if the truck had a bad frontal impact then the frame is not very useful for a swap. Doesn't hurt to try.
Mike
03 4runner Limited
Old 07-22-2021, 07:17 PM #8
Good point. I'll buy that.
Old 07-22-2021, 07:58 PM #9
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
my nightmare
meltdowner is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 10:32 PM #10
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Yea - surprising just those two corners - something nasty must have caught in there. My whole bumper support is kinda crusty. With rust it’s a bad mistake to start try to take thing aparts. In your case the rest of the truck looks good and solid - just a shame for those two parts
Where do you live roughly?
Old 07-23-2021, 09:14 AM #11
Real Name: Chris
Real Name: Chris
South East PA
Old 07-23-2021, 10:51 AM #12
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Id probably try to get an estimate from a local fabrication/ welding shop.
Otherwise - stay on top of craigslist, facebook marketplace, local 4runner/ toyota groups, Theres a 4runner classified FB group, ebay and local junk yards for vehicles being parted out
This is what I had to do to find replacement rear-hatches
Old 07-28-2021, 07:44 PM #13
Real Name: Chris
Real Name: Chris
managed to find a yard in Texas that was willing to ship to Pennsylvania. The guy told me I was luckily I called because he was about to scrap the car because has had it for 3 years and needs to get it off his lot. He's going to cut from the body mount back and I got it all for $100 shipped
Also in the works of a friend of a friend who has an industrial welder that needs electricity ran to it since he has a new location, So if i can help him he will help me for $Free-fitty.
Old 07-29-2021, 12:00 PM #14
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Good deal/ good to hear. Hopefully it all works out well for you
Old 07-29-2021, 04:29 PM #15
MikeinNH67's Avatar
MikeinNH67's Avatar
Can't beat that. Keep us posted and maybe share some pics.
Mike
03 4runner Limited
bumper , crossmember , frame , part , rear
Advice under $25k petron5000 5th gen T4Rs 29 10-31-2018 04:49 PM
Need some advice MK1Power 3rd gen T4Rs 9 01-26-2015 10:54 AM
New 3rd Gen owner looking for some tips(Lift Advice, front end parts advice) Strain 3rd gen T4Rs 2 09-20-2013 10:49 AM
Advice on a 3rd gen BlackCat 3rd gen T4Rs 20 03-08-2012 03:09 PM
Advice: Beware of bad advice from unqualified journalists Thai 4th Gen T4Rs 1 02-05-2003 10:04 AM
