Originally Posted by NCHornet
The way I did it was to use a torpedo level and go right off the bottom of the oil pan on trans. There isn't a large difference between the side rails and the pan and it won't affect the amount of fluid to where it would cause any harm. The biggest factor is to make sure you check the level of the fluid while the car is idling. If you check it with the engine off it can cause you to be 2 to 2.5 quarts low. I was shocked that there was the much difference but there was. I have seen more people do this. I always do a full flush as well, never been a fan of just draining the pan and adding just the fluid that drained out. Make sure you go through all the gears letting it idle a few seconds at each one. This will flush all the fluid through the valve body and it holds more than you would think.
NCH
Thank you mate, that's good to know.
Yes I followed the excellent write-up on this site, it all went very well, I had a bit of a cock-up when finishing off with checking the level, but that's my fault (Forgot to replace the level plug washer with a new one, and took it out with the engine off by mistake! It only lost about 10 fluid oz before I realised what had happened and quickly got the new washer on, I will re-check the level at some point though)
