As you mentioned there are several threads on this, some including CEL some absent CEL
After searching this before, it seems this issue is potentially related to at least 3 things (probably more)
1.) ABS sensor wire - especially if you have had recent suspension work.
2.) Brake switch
3.) Zero point calibration
I haven't dug further as to how to narrow it down, and am usually against randomly throwing parts at a car. Having said that #1 would only be likely if you had some work done, #2 is cheap and easy to replace, #3 is free
I *think* there is a specific way to pull ABS codes if #1 is an issue, but don't quote me on that.
This isn't comprehensive by any means, but I hope its a start!
Keep us posted
