Originally Posted by y=mx+b
Did the shutter change after installing the new pads and rotors? Did you bed the pads properly? If the pads aren't bedded properly, then at a stop while holding the pads against the hot rotors from braking, they can leave a pad deposit and give a false warped rotor feel
When was the last time the tires were balanced and rotated?
I only did the rear pads, and not the rotors, I can definitely give that a try.
I did properly bed the pads over a tank of gas, but the shudder before and after was pretty much the same.
I did get new tires about 2 months ago with a balance, and had an alignment when I did the LCA's.
I did have a seized caliper so I thought for sure it was that and when that didnt fix the issue, I thought it'd be the bushing on the LCA's.
I appreciate the input and questions.
