07-29-2021, 11:38 AM
#16
Originally Posted by sport2004
Thank you for that, had a look at it, but that's probably not something I would mess with.
Alternatively you can get one of these Amazon.com: Cllena Quick Charge 3.0 Dual USB Port Charger Socket for Toyota: Electronics for the center console and connect it to an always on spot in the fuse block using an add-a-fuse. I have both. Having your vehicle on ACC definitely uses a lot more power than what is used to charge a phone. It's also nice to be able to charge a tablet or something overnight without leaving the key in the car when camping!
Originally Posted by MacRendar
Wouldn't this cause potential battery drain issues? Also, how long could someone charge a phone or 2 off of a car battery without any concern of draining too much? I have always been super sketchy about car batteries as I've had to replace so many in my life for various reasons. It's a brand new True start Toyota battery though.
It can if you spend several days in a place and charge a lot of things (family of 4 here, so I know). Charging one or two phones a couple of times won't run down your battery. If you drive every day or two there is definitely no risk of running your battery down (assuming it is in good shape).
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
07-29-2021, 11:50 AM
#17
Real Name: James
Real Name: James
Thanks!
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
07-29-2021, 01:07 PM
#18
Real Name: James
Real Name: James
Appreciate all the comments, guys...
Regards, sport2004
07-31-2021, 03:33 PM
#19
Real Name: James
Real Name: James
Hi guys- Turns out the only other electrical draw when the ignition is in the ACC position is the illumination behind the function window, i.e. time, temp, etc. Nothing major.
Regards, sport2004
08-08-2021, 01:06 PM
#20
I would resort to using the car battery power as a last resort. The small battery packs from Anker and the like are inexpensive and very versatile. My wife and I each have one in our EDC backpack and a car jump start battery in each car.
08-08-2021, 01:24 PM
#21
If you just need to charge electronics like a phone or tablet, I would look into something like this. I don’t have one but worth a shot, you can return it if it doesn’t do great for you.
Solar Power Bank, Qi Portable Charger 10,000mAh External Battery Pack Type C Input Port Dual Flashlight, Compass, Solar Panel Charging (Orange) Amazon.com: Solar Power Bank, Qi Portable Charger 10,000mAh External Battery Pack Type C Input Port Dual Flashlight, Compass, Solar Panel Charging (Orange)
08-08-2021, 02:30 PM
#23
Real Name: James
Real Name: James
Thanks, that looks kinda neat, worth a try, but wouldn't be surprised if it doesn't work without direct sunshine.
Regards, sport2004
08-08-2021, 02:32 PM
#24
Real Name: James
Real Name: James
Originally Posted by Ripper238
Yeah, I make sure the radio and interior lights are off. I charged the phone for up to an hour like this, didn't prevent the vehicle from starting up.
Regards, sport2004
08-08-2021, 02:35 PM
#25
Real Name: James
Real Name: James
Will check that out, thanks.
Regards, sport2004
08-26-2021, 04:24 PM
#26
i went to a drive in movie watching 2 movies in ACC mode listening to the movie audio through my 4runner's audio system. let's say for around 3 hours. it started right up. the audio system of the 4runner probably used a lot more amps. in your case, charging a cell phone and other devices for 2 hours should not discharge your battery assuming your battery is at least 3 years old. if it's older, might be different.
03-31-2022, 11:47 AM
#27
Real Name: James
Real Name: James
Regards, sport2004
03-31-2022, 04:35 PM
#28
Those are great and very popular with the over landing/camping crowds for this exact purpose. It gives you the flexibility to keep it charged while you drive and then use as a charger for your other needs overnight.
*IF* you ever plan on getting a portable fridge (think Dometic or Iceco), you may want to go up to at least a 500 watt unit. They had good sales during Black Friday (on both).
We’re planning on such a setup. Maybe in the next year or so. Depending on how things go.
03-31-2022, 04:37 PM
#29
Another thing I thought of, is use during the “Planned Public Safety Power Shutoff” crap we’re getting every year now once the winds get over 10 mph. I’m in California so the craziness is on another level.
03-31-2022, 04:49 PM
#30
Real Name: James
Real Name: James
No appliances, just phone, camera batteries, small scale lighting, and maybe limited laptop use, this smaller size should do it. Sometimes I cover a lot of roadway sightseeing away from the campsite, so there is some more charging. Not gonna bother with getting solar panels, will try this for starters and see how it goes.
Charging just the phone off the parked vehicle was no problem. Not sure you could do the same charging this battery pack, but it will be interesting to try. For that matter, should probably get a new vehicle battery...duh LOL
Regards, sport2004
