07-28-2021, 01:47 PM
Real Name: James
Real Name: James
Using Vehicle to Charge Devices While Off Grid
Re: 2004 Sport
Of course, with the vehicle ignition off, the lighter socket is not hot. Is there any downside to turning the ignition to the first position, i.e. cluster/dash lights still off, and leaving it there for an hour or so to charge a phone? Is there anything else draining the battery when the ignition is at this position?
Thanks for any insight on this...
(Sorry for the borderline dumb question.)
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
07-28-2021, 02:20 PM
for that short of time charging a phone it should not be an issue at all... providing the battery is in good shape. the ACC position lets you listen to the radio etc without starting the engine.
not too familiar with 2004's but does it have an AC jack in the console or a cig lighter port in the rear cargo area that can be used? my 08 has a standard AC plug in the console box & a cig lighter in the rear cargo area.
07-28-2021, 04:11 PM
The full time 12V mod below solves the issues be provided constant 12v power to all outlets. Well worth the 10 min it takes and you can charge devices over night without running the battery low.
Toyota 4Runner Constant Full Time 12V Power Outlet Mod
Sent from my LM-G820 using Tapatalk
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
07-28-2021, 04:28 PM
Real Name: James
Real Name: James
Originally Posted by firebirdguy
not too familial with 2004's but does it have an AC jack in the console or a cig lighter port in the rear cargo area that can be used? my 08 has a standard AC plug in the console box & a cig lighter in the rear cargo area.
Thanks...it has a cig lighter plug in the console and also in the cargo area. No problems with the battery currently, but it is old.
It does make me wonder about the one in the cargo area. Who's back there when you're on the road?
Regards, sport2004
07-28-2021, 04:32 PM
Real Name: James
Real Name: James
Thank you for that, had a look at it, but that's probably not something I would mess with.
Regards, sport2004
07-28-2021, 04:40 PM
You will be running everything that's on ACC if you do that (Radio, amp's, power windows and the interior lights). I would be worried that the combination would kill the battery if i mistakenly left it in ACC too long with anything else on.
I ran a dedicated constant power acc for this exact purpose.
07-28-2021, 04:54 PM
Real Name: James
Real Name: James
Ok, thanks...what if everything is turned off? Would these still pulling electricity?
If I'm not mistaken, I do believe the interior lights are programmed to turn off by themselves after 10-15 min.
Regards, sport2004
07-28-2021, 06:50 PM
I added 2 quick charge usb's and 12 volt plug to the back and use it all the time when I camp. Since I sleep in the 4runner when I'm solo.
07 SR5 4x4
07-28-2021, 07:03 PM
Real Name: James
Real Name: James
I'll be camping, too, but not sleeping in the vehicle.
Regards, sport2004
07-28-2021, 10:11 PM
Real Name: Lou
Real Name: Lou
Best mod ever!
04 V8 Limited, gray one
07-28-2021, 10:56 PM
Wouldn't this cause potential battery drain issues? Also, how long could someone charge a phone or 2 off of a car battery without any concern of draining too much? I have always been super sketchy about car batteries as I've had to replace so many in my life for various reasons. It's a brand new True start Toyota battery though.
Sent from my moto g(7) using Tapatalk
07-29-2021, 09:52 AM
If you're sure everything's off you should be fine. Most phones now have the ability to rapid charge so you probably won't be charging it more than an hour or so.
07-29-2021, 09:59 AM
A small lithium ion battery pack is indispensable a very versatile for things such as this. Both my wife and I have one.
Can recharge phones, flashlights etc without the worry or hassle. And, you don’t need to bring your 4Runner! ;)
07-29-2021, 10:08 AM
Real Name: James
Real Name: James
I've been considering something like that, as well.
Regards, sport2004
07-29-2021, 11:25 AM
you were asking about the engine off... whos on the road with the engine off?? i figured you meant while camping or not "on the road."
charging a modern phone doesnt take much juice or time so in the ACC position i dont see any issue doing that. ive had the radio on for 2-3 hours at a time occasionally with no signs the battery was drained.
& with the other things off, like the radio/amps it doesnt drain the battery... especially power windows or lights, they dont take any power unless they are being used.
