Old 08-01-2021, 12:37 PM #16
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by southern_runner View Post
Thanks, as you can tell I know nothing about all this. The only "off-roading" this truck will see is a very rough unimproved trail on our hunting property that my 2WD Pilot can handle in all but the worst weather (mud holes).
I bought the wheels for the looks, and the tires were a bonus. I'm going to try and fit them with just the lift kit. If there's excessive rubbing under normal conditions I'll look into trimming.
I also might just sell the tires before they have any wear on them and downsize just a bit. I love the look of them but I definitely don't need a mud tire, I'd be fine with the all-terrains.
I appreciate all the help and input from you guys. There are a lot of things I know some stuff about, and this isn't one of them!
I did get the lift installed, here's a quick pic of the truck with the lift and the wheel/tire combo:
You'll be okay, lots of people run 285s without many issues. As long as its not getting stuffed all the way in the wheel well, you'll probably be fine.
Those wheels probably have enough offset for the tires to clear the UCA without spacers too, which is good
Those G003s are very good tires too
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 11:22 PM #17
southern_runner southern_runner is offline
southern_runner is on a distinguished road
A few people have mentioned the Upper Control Arms. I did a quick search and found this from JBA Offroad:
"JBA Offroad manufacturers upper control arms (also known as UCAs or upper a-arms) for the Toyota 4Runner beginning with the 2003 model year. With the right modifications, Toyota 4Runner models are wonderfully capable off-road vehicles.
All Toyota 4Runner models have independent front suspension and require replacement of factory upper control arms when lifted. If factory UCAs are not replaced, your Toyota 4Runner alignment and clearances will be both incorrect and unsafe.
When Toyota 4Runners are lifted, caster is lost from the front-end alignment. Caster is critical for stability over 45 miles per hour and returns the steering wheel to center after going around a corner. Additionally, factory upper control arms often rub on the front springs at certain articulations. If factory a-arms are not replaced when lifting a Toyota 4Runner, expensive and dangerous damage is likely."
I know their goal is to sell product, but is this something I definitely need to be concerned about?
southern_runner is offline   Reply With QuoteReply With Quote
Old 08-02-2021, 11:18 AM #18
montijo505's Avatar
montijo505's Avatar
For your use, no, you should be fine. If you’re going to be getting into more serious off-roading and upgrading to proper coil overs then yes as in that scenario the UCA limits travel.
As far as trimming, it’s not too much for 285’s. You’ll have to remove the front mud flaps and trim the lower inside lip of the bumper for sure, but not much else.
Old 08-04-2021, 11:00 PM #19
Well maybe I got lucky (buying these without knowing the backspacing, etc)...
I received the RRW Extended Lugs today, and sure enough they let me install these wheels without having to replace my wheel studs. As for the clearance, what do you guys think?
I haven't had a chance to drive it because I am replacing a caliper tomorrow and have the old one off, but I think they're gonna work!
help with a tire size question-20210804_190011-jpg  help with a tire size question-20210804_190729-jpg  help with a tire size question-20210804_190640-jpg
Old 08-04-2021, 11:11 PM #20
y=mx+b's Avatar
y=mx+b's Avatar
Looks good dude!
lift , run , tire , tires , wheels
TRD rim size/tire question mr.walleye 5th gen T4Rs 9 08-07-2019 11:41 PM
Tire size question Uknome 4th Gen T4Rs 4 07-23-2019 02:09 PM
5TH Gen 20" Wheels and Tire - Tire size question DylanTD 4th Gen T4Rs 3 03-27-2017 08:35 PM
Tire Size Question sant6236 4th Gen T4Rs 3 01-13-2009 12:37 PM
1st gen tire size question crazytony Classic T4Rs 7 10-09-2008 03:55 PM
