Old 07-31-2021, 09:48 AM #16
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Originally Posted by alia176 View Post
Yes, mine came with the trans cooler and its a good thing because I tow just about every week. My temps spike on steeper climbs but then comes back down so I don't have a huge concern
From here: auto transmission
Normal operating temperature for an automatic transmission is about the
same as the engine temperature, i.e., about 195°F. The temperature inside the torque converter, while pulling a
big load from a standing start, could easily rise above 350°F. Fluid breakdown often results in harsh shifting and
slip-bump concerns. broken down fluid often exhibits a different coefficient of friction, and foams up easily
causing aeration.
yep the trans cooler definitely helps to regulate temperatures. I wish both engines came stock with one, but wasn't too bad to add one in.
I'd say 350°F is a tad on the spicy side lol. Fluid starts to break down much before that. I don't even like seeing the trans temp consistently above 200. With the cooler though, temps are now much better
y=mx+b is offline   Reply With QuoteReply With Quote
fumoto , oil , pan , thread , transmission
Fumoto Drain Valve Urbanite 4th Gen T4Rs 17 11-30-2020 11:22 AM
Fumoto Drain Valve Mod Snesley Wipes 4th Gen T4Rs 58 06-03-2017 06:02 AM
Fumoto Oil Drain Valve PhdNPrerunners 3rd gen T4Rs 8 01-02-2015 10:27 PM
Where did you bought your Fumoto Drain Valve? Jacobzky 4th Gen T4Rs 13 01-30-2007 11:48 PM
Fumoto oil drain valve? testrider Engines / Suspension / Wheels / Tires / Audio / Accessories 10 06-03-2004 12:40 PM
