Old 08-03-2021, 10:07 PM #1
Monty87ls Monty87ls is offline
Monty87ls is on a distinguished road
Dash replacement worth it?
The dash on my 04 has seen better days. Of course the original owner never bothered to get the dash replaced under warranty smh.
I was at my local pick and pull today to look for something else with no luck but I found a perfect dash! Actually besides the truck needing a bumper and some wheels it was in great shape! even the frame was good! Don't understand why its there. Poor thing is rotting away.
Anyway I can get the dash and the cluster bezel that someone broke (me) for $75!! I think thats a steal but I know its a big job. Im thinking of going tomorrow and pulling it but has any done this? Any tips and tricks or warnings to run away and be happy with my cracks lol
Monty87ls is offline   Reply With QuoteReply With Quote
Old 08-03-2021, 10:48 PM #2
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I'd look at some evaporator core replacement documentation for how to remove the dash
Removing from a junkard first is a good way to figure out how everything comes out before doing it on your own. Doing things the second time is always much smoother
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-03-2021, 11:56 PM #3
Looking into that now, Thanks. Trying to figure out if its worth but man that dash looks good. The whole truck does I just don't get it! makes me curious how many miles are on it.. Maybe I can get it off their website I gotta know! lol
Old 08-03-2021, 11:57 PM #4
93k!! its a baby. Wish it was the same color as mine id buy all the body parts and make my exterior nice and new again haha
Old 08-04-2021, 03:34 PM #5
Got it today. Had it out in 40 Mins with some slight distractions.
Found a guide on it but that said to drop the steering wheel which I didn't find was needed.
Sent from my SM-N975U1 using Tapatalk
Old 08-04-2021, 03:42 PM #6
djpope09 djpope09 is offline
djpope09 will become famous soon enough
Could you post that guide here? My dash is cracked too. I'm not really planning on replacing it, but if I get lucky like you and find a good dash it would be good to have a guide.
djpope09 is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 03:49 PM #7
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
post pictures if you can! Most of us do not have the luxury of "getting another dash". I even checked online for a replacement for mine and it is discontinued. The best option are the coverlays (about $270).
CookieRoe is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 05:32 PM #8
I will when I get home. Honestly it's not bad. Mostly screws, 10mm and 1 12mm bolt.
Old 08-04-2021, 05:34 PM #9
I'll grab some of it out of the car in a bit. For anyone close to dutchess county NY they had another!
The only one had some small imperfections on the right side because someone broke the door panel and it was pushing against it but no cracks i saw. Almost took that one then saw this one.
Old 08-04-2021, 06:08 PM #10
cosmo22nov cosmo22nov is offline
cosmo22nov is on a distinguished road
Don't mean to hi-jack, but I am about to do a dash replacement myself with a clean one from the junk yard. Does anyone know if there is a difference between the 03-05 dash and the 06-09? Toyota calls out different part numbers but I can't see any physical difference between the two. My 4Runner has the JBL system with the center speaker and they're much easier and cheaper to find in the 06-09's.
cosmo22nov is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 11:12 PM #11
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
My ’04 dash cracked after the warranty ended.
I never thought to check junkyards for a new dash cover. I figured they’d be cracked there, too. Thanks for the idea! (I’m nowhere near NY)
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 10:40 AM #12
No clue but I would imagine so but might not be worth the risk idk. I got mine for $75 from an 05. He asked "How does $100 sound?" I said $75 sounds better..
It was a total accident! but if I was gonna do a search Id go to Car-part.com and find out if anyone has some sitting around and go look at them. Pick and pulls would be best option because a lot of places strip the cars and get rid of them.
Old 08-05-2021, 12:11 PM #13
riverwolf riverwolf is offline
riverwolf is on a distinguished road
Mounting is likely identical, especially if the associated hardware stayed the same except for the pad itself. Either connecting parts or the body mounting points themselves would have to change if the dash pad structure was changed in some way with the part number change.
The part number change *probably* indicates when Toyota switched suppliers/materials for the dash pad after the original material was found to have problems with heat/humidity. This wouldn't require changing the mold for the dash pad. You could cross reference to some degree by finding a copy of the TSB for the dash pad replacement...IIRC, it only covered the first few years of 4th Gen production, not the entire run...maybe there's a correlation with the part number change. Who knows, maybe those of us who got replacements under warranty simply received the '06+ part number as well.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 01:30 PM #14
***Cracked Dashboard Action Request***
I ended up skipping the guide and just started stripping what made sense. I kept all the screws and bolts too as spares
Old 08-06-2021, 01:34 AM #15
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Not sure if the different year models have different dashes/part numbers, but there would be 2 different part numbers for my 2004, one with the JBL system that has the center dash speaker and another part number for the non-JBL radios without a center dash speaker.
Edit: Misspelled word, last sentence now says "...without...", instead of "...with..."
2004 Limited V8
$75 , bezel , broke , cluster , dash
Cracked Dash Replacement oceancrest67 4th Gen T4Rs 22 03-15-2016 11:30 PM
Dash speaker replacement help encitrdpro 5th gen T4Rs 5 05-02-2015 12:59 AM
dash replacement fail moloss 4th Gen T4Rs 16 03-07-2015 09:04 AM
Dash lights replacement JHW Maintenance/Detailing 1 01-06-2015 02:53 PM
Rack and Pinion Replacement (Ft. Worth area) Party Boy 3rd gen T4Rs 15 04-08-2014 02:58 PM
