Old 08-07-2021, 11:14 AM #1
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Another wheel bearing question???
So I did some work on my 4Runner last week and noticed that my passenger wheel bearing has some play in it when I pull / push on the wheel from the 12 and 6 o'clock positions. I honestly think I have had a bit of play for sometime. I am getting ready to do a road trip in about 3 weeks. I don't think there is any noticeable noise yet but I don't spend a lot of time in the passenger seat so it is really hard to say.
Is there any reason to rush out and fix it? Usually I am very proactive with repairs but I have had wheel bearings last a long time before getting very loud.
One of the reasons I am very hesitant to replace it is that my experience with aftermarket wheel bearings has not been good. On an old GTP that I had, once I replaced the stock bearings around 100k the aftermarket ones never lasted more than 15k-30k miles. I used both Timken and Moog back then.
Thoughts? Replace? Wait?
Thanks!
zguy1 is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 11:24 AM #2
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Both of those brands are chinese junk. Look for bearing made in japan like NSK or BCA $52 each. Go to rockauto and look at the pictures. They will be stamped Japan.
Its a 2-3 hour job if you have a press. I was at 222,000 miles, so I did mine just as maintenance and peace of mind along with the LBJs.
Torquing the axle nut too tight or too loose is the biggest reason for failure. Dont just bang it on with an impact wrench.
Another wheel bearing question???-2115c46b-266e-4c8c-92b0-8729b6f6b285-jpg
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 12:25 PM #3
zguy1's Avatar
zguy1's Avatar
Thanks for the response. I am guilty of hitting the CV axle with a hammer to separate it from hub. Aside from that, I use a torque wrench for anything suspension or engine related.
Didn't realize you need a press for the bearings. Need to find out where or who can press in a new bearings near me. I also need to find out a better way to remove the CV from the knuckle when replacing CV axles and the hub from the knuckle when doing the bearings.
Old 08-07-2021, 01:11 PM #4
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
This guys been selling complete front hubs over on TW for a number of years now, not sure i have seen any bad reviews.
Just have to bolt it on.
Wheel Bearings & Hubs Press Service *** OE NSK*** | Tacoma World
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 02:06 PM #5
montijo505's Avatar
montijo505's Avatar
Came here to recommend this guys product. I replaced my oem ones with his about threeish years ago. No problems at all, even running super wide -38 offset wheels and 33's for the last two years until recently.
Old 08-08-2021, 08:50 AM #6
Drcoffee's Avatar
Drcoffee's Avatar
How to
Toyota 4x4 how to replace front wheel unit bearings - Metal Tech 4x4
Old 08-08-2021, 11:56 AM #7
zguy1's Avatar
zguy1's Avatar
Thanks. That’s some good information with a lot of detail. Without a press and some specialty tools, it looks near impossible to do correctly.
Going to try and call around to see if anyone can remove and press a new bearing and seal onto my exiting hubs. If not, then I can look into the options offered by others here in this thread for assembled units.
Old 08-08-2021, 12:41 PM #8
Drcoffee's Avatar
Drcoffee's Avatar
Around here CarQuest usually has a machine shop. $20-$40 each to press them in/out. Or if you plan to start diy your repairs, you can buy a 20 ton press at harbor freight for $140 on sale. Mine has paid for itself over and over again
Old 08-08-2021, 01:43 PM #9
weaves weaves is offline
weaves is on a distinguished road
O'Reilly's has a hub puller that you can rent. You can remove the hub while the hub/wheel bearing assembly is still attached to the knuckle if you don't have a vice. For 2WD, you'll need to remove the entire hub assembly since there is a locking nut on the backside holding the hub onto the wheel bearing.
https://www.oreillyauto.com/detail/c...kit/ren1/67213
weaves is offline   Reply With QuoteReply With Quote
Old 08-08-2021, 02:26 PM #10
zguy1's Avatar
zguy1's Avatar
Man, you got me thinking now about a press. I am tempted to check them out at Harbor Freight. I haven't been buying any tools these days since I have most of what I need. Lately I have been renting specialty tools from Oreilly's since they are free and typically don't use them often. I am guessing I would need the OTC bearing separator tool as well. Not sure if that can be rented or what the cost is.
Old 08-08-2021, 02:28 PM #11
zguy1's Avatar
zguy1's Avatar
Thanks. I am guessing you would use this tool regardless of whether pulling the hub on the car or while the knuckle is in a vice???
Old 08-08-2021, 02:38 PM #12
Drcoffee's Avatar
Drcoffee's Avatar
The large splitter at HF isnt big enough. I found a used splitter on ebay that was 7” from screw to screw and its perfect for any job. Truck parts are bigger.
Old 08-08-2021, 02:40 PM #13
Yes but you don't need to remove the knuckle. Just the hub/wheel bearing assembly. If you have 4WD, it's actually easier to use to puller while the assembly is still bolted to the knuckle (still attached to the vehicle). Once you remove the hub, then you can unbolt the wheel bearing.
Old 08-09-2021, 09:04 AM #14
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
This technique is fine but the trick is to leave the nut threaded on flush with the end of the shaft. That way you don't deform the threads on the end when going to town with a BFH.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 09:21 AM #15
zguy1's Avatar
zguy1's Avatar
I have always left the nut on and flush when doing so.
aftermarket , bearings , replace , time , wheel
Wheel bearing question? stecow 3rd gen T4Rs 8 11-28-2018 01:49 PM
Wheel Bearing question iAlex684 4th Gen T4Rs 7 07-05-2016 02:28 PM
Front wheel bearing question drmoreau 3rd gen T4Rs 2 10-22-2015 12:32 PM
wheel bearing question sky88s 3rd gen T4Rs 9 12-19-2011 02:07 AM
Wheel Bearing Question.... Tenn_volsfan56 3rd gen T4Rs 5 08-22-2011 05:41 PM
