Old 09-25-2021, 11:45 PM #1
KeepingMy_ShirtOn KeepingMy_ShirtOn is offline
KeepingMy_ShirtOn is on a distinguished road
Anyone with 5th gen springs and 5100s?
Trying to figure out what I would need in the rear spacer wise if I threw some 5th gen springs in with 5100's at 1.75 setting or are these basically like the FJ's?
If anyone is running something like this post up because FJ springs are hard to find these days!
KeepingMy_ShirtOn is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 07:40 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
I知 running this. I think you値l be level if you run it. The 5th gen springs will give you about an inch of lift. I知 at at 0.85 setting on the front and happy with the rake I have. If you run 1.75 you値l probably be level but any significant weight in the rear or towing and you値l be squatting in the back
Old 09-26-2021, 08:23 PM #3
__tolbs __tolbs is offline
__tolbs is on a distinguished road
Which 5th gen springs did you use? Are they all the same?
__tolbs is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 09:45 PM #4
Any pics? I was looking to add a spacer in the rear either way. I have a drawer system that stays in and is full of gear + two bikes so nothing too crazy weight wise. I can find 5th gen springs for cheap all day locally but can't nail find FJ's anywhere.
Old 09-26-2021, 09:47 PM #5
Should be all the same with exception of the TRD PRO's
Old 09-26-2021, 11:02 PM #6
pcos55 pcos55 is offline
pcos55 is on a distinguished road
You'll want to add a 1.5 rear spacer to avoid negative rake. 5th gen springs have an extra coil than the 4th gens but are the same height (when new).
There's really no reason to use FJ rear springs over 5th gen. 5th gen springs are slightly taller, and slightly stiffer.
pcos55 is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 11:36 PM #7
Okay cool... so I can add Moog FJ fronts and 5th gen rears+ 1.5"spacer or just 5th gen all the way around + 1.5 spacer and either way it should come out to be around the same look/performance. I'm looking for just a small rake.
Old 09-27-2021, 08:02 PM #8
Syr4RinNC's Avatar
Syr4RinNC's Avatar
The sliders make it seem like there is less lift than there is. You get a better idea in the photo without the sliders
Shared album - Bryan - Google Photos
Old 09-27-2021, 11:13 PM #9
thanks! i'm nothing looking for anything crazy.
Old 10-05-2021, 12:34 AM #10
AlpinUltra AlpinUltra is offline
AlpinUltra is on a distinguished road
Looking good!
What size tires have you got on there? Any rub?
AlpinUltra is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 10:30 AM #11
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Falken wildpeak 265 70 17 - they池e on the bigger side for this size at almost 32 inches. No rub. Next step is 255 80 17
5100s , 5th , gen , hard , springs
Which Springs with 5100s? Colorado S14 5th gen T4Rs 14 07-01-2019 01:30 AM
2 inch springs? .. with my 5100s.. OME? silversx 5th gen T4Rs 9 07-11-2011 03:51 AM
FJ springs and 5100s done..... but lewjonesrd25 4th Gen T4Rs 10 05-25-2011 08:55 PM
Bilstein 5100s and FJ springs lewjonesrd25 4th Gen T4Rs 1 05-23-2011 11:47 PM
04 with FJ Springs and 5100s asnatlas Engines / Suspension / Wheels / Tires / Audio / Accessories 18 04-11-2011 04:41 PM
