Old 08-09-2021, 08:11 AM #1
Kbeanz3330 Kbeanz3330 is offline
Kbeanz3330 is on a distinguished road
Kbeanz 4th Gen OEM+ Projector Retrofit Build
I finally reached my 15 post minimum so here we are with the short and sweet journey of my headlight build.
Parts List:
Morimoto D2S 5.0
Morimoto xb4500k D2s bulbs
Matsushita Gen. 3 Ballasts & Igniters
TRS Relay Harness
Profile Hi-Lens V1
2007 4Runner Limited 92k miles, this car was given to me by the in-laws. All stock, unmolested, original owner, mom driven, and some nice sun faded halogen headlights.
I thought about sourcing a set of lens's just to swap, but ended up buying a new set of headlights off amazon for $150. This allowed me not to have the vehicle down and take my time building the new lights in the basement.
After disassembly I was able to take measurements of all the factory mounting points. Made this adapter bracket and 3D printed it.
Projector sitting in my bracket nicely.
Profile Hi-Lens sitting in the highbeam bucket. I thought about doing a true quad projector retrofit but aiming is too stressful and it would have driven my OCD crazy.
Projector and led high beams mounted. In the first couple pictures you can see that I opted to go with the FGL on the projector. For those of you that don't know, Foreground limiters function by blocking a lot of the light that would normally go right on the ground in front of the car. Foreground light gives the appearance of brighter headlights but it is just a placebo effect, when you drive at night you look at the road ahead of you not directly in front of your bumper. In this case more light/lumens are sent down the road rather that right in front of your car.
Water-proofing the ballasts since these will be mounted on the underside of the headlight. Normally I would try and fit them inside but there just wasn't enough room.
Kbeanz3330 is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 09:22 AM #2
Ballasts mounted underneath and buttoned up with dust boots.
Testing feat. a beautiful cutoff
Complete and re-assembly.
Mounted on the truck: before & after
I love the subtle look of the blue coated lens on the D2S 5.0
I still need to do some beam adjustment and get some night time output shots. Hope you guys enjoyed, let me know what you think!
- Kbeanz
Old 08-09-2021, 10:48 AM #3
blkexp98 blkexp98 is offline
blkexp98 is on a distinguished road
Looking good. I think you were smart to stay with led on the highs. I'm no expert but I think HID doesn't like to be turned on and off quick so led is better for that application. Could you go into your procedure for aiming the headlights?
Sent from my SM-G975U using Tapatalk
2007 Limited 4Runner
4x4 V8
blkexp98 is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 11:11 AM #4
montijo505's Avatar
montijo505's Avatar
Turned out really clean!
Old 08-09-2021, 05:57 PM #5
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
very nice, hope you don't run out of low beam adjustment, when our rigs are lifted, the projectors tend to hit the shroud on the final adjustment, I'm pretty close with my s2000 projectors. if you can, grind out some parts of the shroud to make more clearance.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 06:50 PM #6
It's funny you say that because thats exactly what happened to me, I have to take the lights back apart and mount the projector on the other side of my bracket to buy a couple mm's of clearance.
Old 08-09-2021, 07:36 PM #7
Neosapian Neosapian is offline
Neosapian is on a distinguished road
Nice work! Thanks for sharing these images!
Neosapian is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 09:16 PM #8
Bogrun's Avatar
Bogrun Bogrun is offline
Bogrun will become famous soon enough
Bogrun's Avatar
Awesome project and write-up!
Fog lights next?
Bogrun is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 01:35 AM #9
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
bro me toooo haha. If I open it up again might upgrade my projectors.
also op would you sell those brackets by chance?
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 04:05 AM #10
riceandpho's Avatar
riceandpho's Avatar
i have done retro with the older style bracket for the d2s 2.0 projector.
its good for what it is, they have the newer style brackets for newer projectors.
these are a very good option for folks that need a quick job without all the extra work.
this light hobby has gotten me using only oem projectors and not using the aftermarket projector. why im more old school, tuned oem projectors are pretty cool when you have experience the performance of those. started with the md2s 2.0 , then moved to a rx330, then to current s2000 on my truck and a rx350 on my lady's camry. they are good at what they are. ones better than the other.
03-09 4Runner D2S 5.0-G5-R Brackets – Lightwerkz Global Inc
Old 08-10-2021, 04:06 AM #11
riceandpho's Avatar
riceandpho's Avatar
I would try that and also if you can, slowly grind the back of the shroud. might need to enlarge the circle. practice on a used set of lights first.
Old 08-10-2021, 11:36 AM #12
Fog lights next?
Yup, plan on 3d printing some brackets for fogs. Thinking of making an adapter for the morimoto fog lights to drop into our 4th gens.
Old 08-10-2021, 11:38 AM #13
Yeah I would sell them if people were interested.
Old 08-11-2021, 01:13 AM #14
yeah thank you. i actually am using this bracket right on for d2s 4.0.
07 SR5 4x4
Old 08-14-2021, 11:19 PM #15
AlpinUltra AlpinUltra is offline
AlpinUltra is on a distinguished road
Nicely done, sir. They look great on the truck, great use of a 3D printed part!
AlpinUltra is offline   Reply With QuoteReply With Quote
92k , build , kbeanz , limited , miles
Another Projector retrofit gshadow325 4th Gen T4Rs 17 07-10-2015 04:27 AM
Projector retrofit? 42s on u 3rd gen T4Rs 8 08-06-2013 03:09 PM
FX-R projector retrofit DIY Hbryanlopez 5th gen T4Rs 9 07-07-2012 11:04 AM
Get a projector retrofit for your 3rd gen! so_LED 3rd gen T4Rs 23 02-21-2012 03:17 PM
HID Projector for retrofit... beirish 4th Gen T4Rs 1 04-10-2007 01:00 PM
