Old 03-08-2022, 06:48 PM #16
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
New O2 Sensors (X4) and CV axle seal install (was leaking on passenger side). Stripped the diff drain plug and had to weld a socket onto it to remove.
Also installed a new rear hatch actuator so it doesn't rattle loose on washboard roads like the old one.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 03-09-2022, 02:33 PM #17
moshrider3 moshrider3 is offline
moshrider3 is on a distinguished road
Wow over 500,000 miles that’s incredible. I’m curious as to how you welded the manifold on the passenger side. Did you remove it and then weld it or with it on the vehicle?
moshrider3 is offline   Reply With QuoteReply With Quote
Old 03-10-2022, 05:59 PM #18
Hi moshrider,
I removed the exhaust manifold from the vehicle, TIG welded it, then reinstalled with a new gasket and new lock nuts.
Old 03-11-2022, 12:21 PM #19
RBLACAUSA's Avatar
RBLACAUSA RBLACAUSA is offline
RBLACAUSA is on a distinguished road
RBLACAUSA's Avatar
Originally Posted by randy88fj62 View Post
Replaced my steering rack, all new PS hoses, and new PS pump. System is very responsive. Was able to shoe horn the rack in with the inner TREs on but had to remove oil filter to do it. Noticed front diff driver's side bushing is worn, need to replace those.
Next up will be pan hard correction bracket so the rear geometry will be corrected with the lift.
Truck now at 521,500 miles with original engine, trans, etc.
Can you post up what parts #s you used? I just posted up a new thread looking for info on rack repalcement on an '04 V8. Will probably forego the pump tho.
500k+ miles...wow...I'm only at 119k and original owner. At this rate I'll hit half a million when I'm over 115 yrs old lol.
'04 4Runner 4X4 SE V8
'06 4Runner 4X2 SE V8
'03 4Runner 4X2 Lmtd V8
'06 LX470
RBLACAUSA is offline   Reply With QuoteReply With Quote
Old 03-12-2022, 02:03 PM #20
Ralph Blake Ralph Blake is offline
Ralph Blake is on a distinguished road
With my 08 4Runner having only 8938 miles as of today, guess it’s going to be a while till I face these rebuilding items.
Ralph Blake is offline   Reply With QuoteReply With Quote
Old 03-12-2022, 06:42 PM #21
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You must live close to the mall.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 03-13-2022, 12:43 PM #22
No I just don’t spend my life driving all over.
Old 03-13-2022, 08:41 PM #23
meltdowner meltdowner is offline
Real Name: Tim
meltdowner is on a distinguished road
Real Name: Tim
9k miles?! awesome. I'm at 72k and thought I was low! 06'
meltdowner is offline   Reply With QuoteReply With Quote
Old 03-14-2022, 12:00 PM #24
These are the notes I had:
Power Steering Hoses
reservoir low pressure line 4434835250
No 2 return line 4441735011
Return Assemby No 1: 4440635021
Main pressure feed line hydraulic assemby hose 4441335010
crush washer? 44327-30040
4 quarts of Toyota ATF WS 00289-ATFWS
Old 04-20-2022, 11:48 AM #25
Replaced belt tensioner this past weekend. What a pain. I had to pull loosen the alternator and let it rest on the frame. Also had to remove the power steering pump pulley and the timing belt No 2 cover. Took way longer than any other vehicle I have worked on.
Old 06-06-2022, 12:17 PM #26
Hopped the truck hard wheeling over Labor Day and ended up stripping off 5 teeth on the ring gear. Threw a used one in this past weekend.
While I was working I added the pan hard correction bracket, new akebono rear brake pads, and all new ebrake hardware (shoes looked good for now). Also added new rear caliper brake lines and extended stainless lines coming from frame down to axle.
When the axles were out one side wheel bearing had some rust in there from water intrusion so rebuilding the rear axles with new bearings will have to happen in the next year or sooner.
Old 06-06-2022, 08:00 PM #27
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You ARE the "repair Meister"!
arb , front , lights , oem , rear
2014 Trail Edition Premium 50K-Mile Overland-Build mrbrenan For Sale: Vehicles 1 04-29-2021 03:22 PM
2002 Sport Edition Build BondoMN 3rd gen T4Rs 26 03-12-2021 09:44 AM
Niteghost's 02 Sport Build and Maintenance Thread Niteghost 3rd gen T4Rs 12 11-05-2020 05:09 PM
wkeryder4's Build Thread - 07 Sport Edition 4x4 wkeryder4 4th Gen T4Rs 118 10-08-2019 08:12 PM
Squishmitten's 02 Sport Edition Build squishmitten 3rd gen T4Rs 93 06-09-2019 02:27 PM
