Old 08-12-2021, 01:07 AM #1
pcos55 pcos55 is offline
pcos55 is on a distinguished road
2UZ-FE V8 Leaking from oil filter adapter?
I was wondering if anyone has seen this issue before, as it seems very uncommon. There are steady drips of oil coming from the Engine Oil Filter Adapter while the engine is running. Oil comes from behind the bolt pictured, my guess is from the o-ring between the adapter and block.
2UZ-FE V8 Leaking from oil filter adapter?-screenshot_20210812-005802_gallery-jpg  2UZ-FE V8 Leaking from oil filter adapter?-5f7fd8bdd4cbed4050b1c141a635c920-png  2UZ-FE V8 Leaking from oil filter adapter?-w01331982488oes_1-jpg
pcos55 is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 12:17 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Have an '03 V8 so keep us posted on your repair. Thanks.
Old 08-12-2021, 04:29 PM #3
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
I'm at 373xxx mileage and don't have any leaks at this location. For that matter, I have no leaks anywhere on the engine, knock on wood.
I wonder if the O ring is indeed the cause of your leak?
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 04:52 PM #4
DoctorPopcorn's Avatar
DoctorPopcorn DoctorPopcorn is offline
Real Name: Tyler
DoctorPopcorn is on a distinguished road
Real Name: Tyler
Is there any chance this could be the oil pressure sensor leaking? I had a good leak on my '05 when I bought it last year, and the dealer even noted it was the oil pressure sensor when they were doing the timing belt and water pump.
I changed it with an O'Reilly brand part out of haste, but I'd do OEM if I could go back. It was pretty easy to get to, just behind the filter, but you need a deep 22mm, I think?. As always, my biggest challenge was unclipping the plug connection. I still have another oil leak somewhere, looks like the driver valve cover, but I don't lose a noticeable amount between OCs. I tightened my VCGs bolts with a 1/4 ratchet as some weren't even finger-tight.
It's funny, too, because I had just changed the oil pressure sensor on my '98 and it was the main cause for me losing almost a quart every 1-2 weeks. Fixed my issue.
'98 Limited 4X4 320K (summer truck): OME/5100 lift, LT235/85/16 AT3W WPs, supporting mods, many trails, on 3rd rear diff. Rust.
'05 V8 Sport 4WD 250K (DD, was hoping for pavement princess, turned out to be a work horse): IronMan 4X4 Nitro Gas Stage 2: 2.5" 0-110 lb front, 3" 440-880 lb rear. Sway bar(s). LT255/80/17 Falken AT3Ws. URD Y pipe, Slyfox75 AIP Bypass. Also rust.
DoctorPopcorn is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 07:21 PM #5
It was the indicated gasket that was causing the issue. Total pain in the ass as you have to drain the cooling system to get the oil filter housing out.
340k on this engine. No leaks now.
Old 09-20-2021, 08:58 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I'm glad you got the leak fixed!!
But just for future reference to help others that may end up having this issue, could you explain why the cooling system has to be drained to replace the gasket?
2004 Limited V8
Old 09-20-2021, 09:11 PM #7
There are cooling lines attached to the oil filter adapter, as shown in the diagram.
Old 09-20-2021, 11:07 PM #8
BostonJon BostonJon is offline
BostonJon will become famous soon enough
it's an oil cooler i believe. the 3rd gens have them too.
BostonJon is offline   Reply With QuoteReply With Quote
Old 10-12-2022, 03:26 AM #9
MidWesterner MidWesterner is offline
MidWesterner is on a distinguished road
I know this is an old thread, and i apologize...but I found a relevant video with step by step for this exact repair. I believe my 03 is doing the same exact thing, as I have little puddles from time to time on the ground, and it looks like someone lathered up the undercarraiage like a thanksgiving turkey before sticking it in the oven.
Toyota 2UZ-FE Engine Oil Filter Adapter Seal Replacement - YouTube
MidWesterner is offline   Reply With QuoteReply With Quote
Old 10-12-2022, 03:12 PM #10
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Yes, excellent video, Peter, loves his work!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-12-2022, 05:42 PM #11
gookies gookies is offline
gookies is on a distinguished road
Thank you, bookmarked for future reference, I was wondering why OP couldn't just clamp the hoses instead of draining. This videos shows that you can just do that. Should be a pretty simple repair if mine starts to leak.
Engine Oil Filter Adapter Seal - Toyota (15692-50020) - Should be around $1.50 at your dealership.
gookies is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 07:10 PM #12
theladyviola's Avatar
theladyviola theladyviola is offline
theladyviola will become famous soon enough
Had the same leak. The old gasket was about as hard as a rock when I finally got it out.
theladyviola is offline   Reply With QuoteReply With Quote
2uz-fe , adapter , engine , filter , oil
Aluminum Oil filter cap assy leaking skag1T 5th gen T4Rs 18 07-15-2021 02:22 PM
Does the Baxter filter adapter loosen up when you spin the filter off? Nobody Special 5th gen T4Rs 6 01-13-2021 08:52 PM
5th Gen 72k Miles, Oil Filter Leaking, Need Help pinkstarjess Problems & Warranty Issues 6 11-18-2019 06:55 PM
Cartridge filter adapter swampdodo Off Topic 2 08-18-2018 10:52 PM
Leaking fuel filter question clt750 3rd gen T4Rs 4 06-22-2013 09:33 PM
