Old 08-15-2021, 12:17 PM #1
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
Stuck “Steering Stop” LBJ Attachment Help
I’m trying to change my LBJs
The steering stop attachment (I can’t find a name for this part except this) is stuck. I’m an hour or more round trip to get a pickle fork.
I can’t get it to drop. Have gently tapped it while prying hard!
Have it soaking in Kroil.
Anybody got a solution?
I’ve tried attaching a pic and linking a pic. Syntax is right. Anyone know why neither pic is showing up?
Been a while since I posted here. This is the reason. Glitchy as hell to use.
-30495e2e-4b84-43e3-a926-fa3b1d1b9d92-jpg
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 08-15-2021, 12:30 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Your pictures won't open for me, I assume you are talking about the piece held on with 2 bolts that will release the LCA. It should come off fairly easy but I recall having to apply some heat on one to get it to separate.
Replacing the LBJ is a big job, I opted for new LCA from 1Aauto that come with new LBJ and are about $200 per side. They come with new bushings too.
Old 08-15-2021, 12:31 PM #3
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Been a while posting here. This is the reason. Glitchy as hell to use.
If you're replacing the ball joints, easiest way is the destructive route since you don't need them anymore. Cut the ball joint taper between that intermediate attachment plate and the LCA. Then use a ball joint press to pop out each fragment. You'll need a nice carbide sawzall blade because the material is really hard. I used diablo carbide speed demon for thick metal blades or something along those lines
I usually upload my images to a 3rd party host (imgur in my case) and then embed. you can embed from flikr, google photos (have to open viewership to anyone with link), or other similar. This is what I do: https://www.toyota-4runner.org/3549755-post34683.html
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-15-2021, 12:37 PM #4
Slowgoat's Avatar
Slowgoat's Avatar
Thanks. That’s the one.
I only do OEM. Have 555 OEM ball joints and the press ready to go.
May try heat.
Pics are small enough and are in the correct format. And the show up in previews. Dumb. Who knows??
How are yours holding up?
Old 08-15-2021, 12:39 PM #5
Slowgoat's Avatar
Slowgoat's Avatar
Thanks. I linked an Imgur pic. It’s not showing up.
Here it is:
Old 08-15-2021, 12:57 PM #6
y=mx+b's Avatar
y=mx+b's Avatar
Here it is:
Need the file extension on the end
HTML Code:
Without extension
[img]https://imgur.com/5GNxARS[/img]
With extension
[img]https://imgur.com/5GNxARS.jpg[/img]
Without extension
With extension
Can even do linked BBcode, where clicking will bring the user to look at the image on imgur. Imgur will provide this to you to just copy when looking at the images and embedding options. If you downsize the image when embedding for formatting/fitment reasons, then clicking and redirecting to imgur will allow it to open full size
HTML Code:
format
[url=ImgUrlWithoutExtension][img]ImgUrlWithExtensionAndOptionallySize.jpg[/img][/url]
[url=https://imgur.com/5GNxARS][img]https://imgur.com/5GNxARSm.jpg[/img][/url] (last m inside img tag before the extension is the image size s=small, m=medium, l=large)
Old 08-15-2021, 03:02 PM #7
montijo505's Avatar
montijo505's Avatar
I placed it upside down (threaded portion of lbj sticking up) and used a couple of pieces of wood touching only that piece you mention. Apply heat and then wack the threaded lbj shaft and it’ll pop off.
Watch this video at 8:30 to see what I mean.
2nd Gen Toyota Tacoma Lower Control Arm Rebuild Ball Joint and Bushing Replacement - YouTube
Old 08-15-2021, 03:45 PM #8
Slowgoat's Avatar
Slowgoat's Avatar
HTML Code:
Without extension
With extension
Without extension
With extension
HTML Code:
format
When you go into Imgur the only option on a phone is to do the link that I linked. All the other options aren’t there. FYI.
Old 08-15-2021, 04:06 PM #9
Slowgoat's Avatar
Slowgoat's Avatar
In the end MAP gas and a pickle fork did it.
attachment , can’t , i’m , stuck , trip
Front lower ball joint attachment and steering knuckle wont align Xhado 5th gen T4Rs 19 04-30-2018 10:32 PM
Steering stop covers bassmacka 4th Gen T4Rs 6 03-02-2017 11:12 PM
Stuck Steering JohnJMonroe 3rd gen T4Rs 4 11-14-2014 07:25 PM
lucas power steering leak stop ScarabArtistry Classic T4Rs 12 06-09-2012 11:46 PM
Steering Stop JP4RNR 4th Gen T4Rs 1 01-14-2008 03:32 PM
