08-15-2021, 01:45 PM
Headlights - finding OEM replacement
My 4Runner is a Japanese import - I had assumed it would use the same headlights as the 2007 Hilux truck we have here (I don't think it was offered for sale in the USA) but the design looks slightly different.
I am just looking into my options in the unfortunate event I have an accident - I think importing parts from Japan may be prohibitive, so I wondered about a Hilux front end swap.
My truck has some sort of after marker lower front spoiler on, ignore that.
UK Spec truck
My truck (See the lower part of the headlights is recessed slightly)
Any ideas guys? Hard to believe they use different headlights for right hand drive spec vehicles but there it is!
Cheers!
2008 2.7 2WD 4 speed (Tacoma-Runner?)
08-15-2021, 02:58 PM
UK Spec truck
Cheers!
Can you get a better picture of yours? They look just like the ones on the American 4Runner
08-15-2021, 03:01 PM
Do you mean the top pic? Sorry that was just one from Google, of a UK Spec Hilux truck. I'll see if I can find a better one, unfortunately the American spec ones would be set up for Left hand drive. (You would not believe how useless the image results for "2007 Hilux" are)
If you mean the bottom pic, you can click on it for a full size version
Edit: OK here is a much better pic of the Hilux Extra Cab Exterior (2007 – 2009)
08-15-2021, 04:09 PM
Looks like the pre-2007 American headlight.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
08-15-2021, 04:31 PM
Yes that's what I don't understand, when I look up "4th gen 4Runner" I see some have that little recessed/notched section, and some don't.
Anyone know what it's for?
I suppose worst case I'd have to get a custom bodyshop to get Hilux headlights to fit somehow.
08-15-2021, 05:32 PM
Real Name: Skip
Real Name: Skip
What being said is that the headlights on your 2007 4th Gen Japanese right hand drive T4R are the same as the headlights on 2006-2009 4th Gen American left hand drive T4Rs, there's no difference in the headlights because of which side the steering wheel is on.
2003-2005 4th Gen T4Rs have a slightly different headlight shape which is why you see some 4th Gens with different headlights, so what you need to find is a source for headlights from the later 4th Gens, 2006 through 2009 models.
I'm pretty sure you will not get those Hilux headlights to fit correctly, because the shape is wrong and I'm sure the mounting tabs will also not line up.
You need to look for a Hilux Surf headlights source, are there any countries in Europe that has Hilux Surfs?
2004 Limited V8
08-16-2021, 07:07 AM
the lights from america Lhd will have the wrong cutoff in the projectors to be used in your area, you need to look for hilux surf 215 for the Rhd market. light will fit, but the output wont be correct.
look for hilux surf 215 i think.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
08-16-2021, 01:14 PM
Thanks chaps, I think it might mean getting some from Japan after all then - the closest RHD country where they were sold domestically!
Europe is all left hand drive and don't think the 4Runner/Surf ever got officially imported there either, after the 3rd gen.
Good idea to search for GRN215 though, that might come up with something in future, thanks.
08-17-2021, 02:09 PM
Real Name: Ed
Real Name: Ed
Try Partsouq too for RHD parts
08-18-2021, 01:03 PM
Either try Japan, Australia/NZ or some island like Jamaica.
Like previously said, the lights point in the wrong direction and the cutoff is not correct if you buy from North America or any left hand drive country.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
08-19-2021, 11:21 AM
I didn't know about that site, thanks! Headlights out of stock but I will bookmark it for the future.
08-19-2021, 11:23 AM
Yup, I think Japan will be the closest source to this damp little RHD rock!
