Old 08-15-2021, 11:24 PM #1
Urbanite Urbanite is offline
Urbanite is on a distinguished road
Oil Filter Wrench Size
I've gone to a few auto parts stores as well as Walmart and Ace Hardware, but none has the correct size for the OEM oil filter wrench our trucks use. I'm not looking for the band, strap, or universal type wrench and I'm not willing to pay the dealer their outrageous price for that wrench. The type I'm searching for is the one pictured here. Mine is a V6, not sure if V8 uses the same. If you have any leads that would be awesome. Thanks.
Oil Filter Wrench Size-20210815_200302-jpg
Urbanite is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 12:20 AM #2
triethylborane triethylborane is offline
triethylborane will become famous soon enough
The one I have used successfully on my V6 is labeled 73mm with 14 flutes and 3/8" drive. Its a Capri tool that also fits a 996 T 3.6, so I think its maintained the dimensions. Id check Amazon lol
triethylborane is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 12:22 AM #3
montijo505's Avatar
montijo505's Avatar
I use this one, no issues!
uxcell A16041800ux1249 14 Flutes 73mm Inside Dia Cap Type Car Oil Filter Wrench Cup for Lexus Amazon.com: uxcell A16041800ux1249 14 Flutes 73mm Inside Dia Cap Type Car Oil Filter Wrench Cup for Lexus: Automotive
Edit: forgot to specify, this fits the YZZD3 Toyota filters perfect. Not an issue for me as I always use Toyota filters.
Old 08-16-2021, 08:42 AM #4
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
There is no specific / universal filter wrench for “your” vehicle. Every filter brand is unique in size. Bring your new or favorite filter to advance auto parts and choose the wrench that fits it. They come in various sizes. One will fit and the cost $5-&10. Dont over complicate it.
If you switch filter brands, your wrench may no longer fit. I’m partial to Purolator filters
*Handy tip #354, with a permanent marker, write the milage of when you installed the filter, on the filter itself. When you see 176,000 on the filter, and you are now at 182,000 miles, its time for an oil change.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 11:49 AM #5
the universal band type filter wrenches work great & avoid the hassle you are running into here where you cant find the right size specific for your filter.
& on these V6 engines, its so easy to get to the filter that if you or a previous person doesnt over tighten it, they can usually be removed by hand. then when installing a new filter dont gorilla tighten it down... i install & remove most my filters by hand, with a properly lubed gasket they only need about 1/2-3/4 turn to seal.
Old 08-16-2021, 01:17 PM #6
riverwolf riverwolf is offline
riverwolf is on a distinguished road
As others have said, filter cap wrenches aren't vehicle specific. It's specific to the filter used, although I would imagine (unconfirmed theory) manufacturers more-or-less tend to use the same diameter/flute arrangement for filters with the same vehicle application.
If you only need to use a wrench for removal, I'm a fan of the 3-claw universal ratcheting gizmos...about $8 from most vendors. Allows me to cover everything from my lawn mower filter to my dad's F-150 (that filter is at the upper end of the tool's diameter spec).
However, if you have a reason to need a tool for installation where you feel you can't get proper torque via hand tightening (ex. Purolator specs 3/4 to 1 turn after the gasket makes contact), the cap wrenches are the way to go, just be careful not to over tighten and distort the gasket. The universal claw tends to crush the filter a little, at least with Purolators. Harbor Freight has this kit of 6 caps in case you have multiple vehicle sizes to service or different branded filters for the 4Runner need a different cap. No personal experience...Good luck!
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 03:31 PM #7
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I've never used an oil filter wrench on my v6. They don't need to be tightened too the moon, gasket does a fine job with them on there hand tight. A little fresh oil on the gasket helps to prevent them from sticking when removing. I also write the mileage on the filter
y=mx+b is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 07:09 PM #8
Syr4RinNC's Avatar
Syr4RinNC Syr4RinNC is online now
Syr4RinNC's Avatar
Not adding anything- but agree with all. Certainly when you install them they just need to be snugged. That said I have had a few that get really wedged on there and ive had to resort to some more challenging ways to remove them.
I always use different filters depending on the deal I find, so it is frustrating that my socket/ wrench doesnt always fit
Syr4RinNC is online now   Reply With QuoteReply With Quote
Old 08-16-2021, 08:40 PM #9
montijo505's Avatar
montijo505's Avatar
Buy in bulk at the dealership and avoid that problem lol
Old 08-17-2021, 12:16 AM #10
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
+1 to buying in bulk. I bought a case of 10 OEM filters and 10 drain plug gaskets a long time ago, and I still have a few left.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 08-17-2021, 10:27 AM #11
montijo505's Avatar
montijo505's Avatar
Even if you buy a half case, that’s five filters. At 5k intervals depending on how much you drive that’s at least a couple years worth. I have a fumoto valve so no crush washers for me. Makes the whole thing even easier.
Old 08-17-2021, 12:56 PM #12
ads2539's Avatar
ads2539's Avatar
I just installed my fumoto valve, so I won’t need the 3 crush washers I have left ($1 ea).
Old 08-17-2021, 11:30 PM #13
Kevin G. Kevin G. is offline
Kevin G. is on a distinguished road
I bought an EXACT fit cap wrench, for my 2008 T4R V8 Sport, at Advance Auto Parts....12 years ago.
I had a Toyota factory filter in hand, when I was in the store.
The wrench is a virtual slip-fit over the factory filter end.
Hope this helps.
Kevin
Kevin G. is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 02:33 AM #14
weaves weaves is offline
weaves is on a distinguished road
Those are nice, except on some diesels, which can be torqued on there pretty good causes the jaws to dig into the filter and collapse it.
This style works similarly except it uses teeth to grip onto the filter. Hands down the best one I've used.
Oil Filter Wrench Size-universal-oil-filter-wrench-jpg
weaves is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 07:40 AM #15
Drcoffee's Avatar
Drcoffee's Avatar
Does the valve allow the thick oil to fully drain from the bottom of the oil pan? Looks to me like the valve threads would stand too tall in the pan stopping all the crud from draining completely. Id be curious, once you drain with the valve, remove the valve and see if anything more drains out.
Downside to buying in bulk, I have 5 $8 filters now for a Lexus car I no longer own. I buy 1-2 at a time now. Alway keep one in reserve. And reuse the crush washers forever.
filter , oil , size , type , wrench
Oil filter wrench for 5th Gen enolasfinest 5th gen T4Rs 10 04-02-2019 05:05 PM
Oil Filter and Wrench psa5555 Maintenance/Detailing 0 08-13-2013 08:31 PM
Oil Filter Cap Wrench?? Kevin G. 4th Gen T4Rs 14 11-17-2009 04:53 PM
Oil filter wrench/kit? EdmontonOiler 3rd gen T4Rs 4 09-20-2009 04:08 AM
Oil filter wrench for 4th gen V8 4RNR-LOVN Maintenance/Detailing 9 01-18-2005 09:50 AM
