Old 08-16-2021, 08:28 PM #1
mooockie mooockie is offline
mooockie is on a distinguished road
03 V8 changed 02 sensor now won't idle
I have an 03 with the V8. I just changed the Bank 1, Sensor 1 02 sensor (Denso 234-4138). Unhooked the battery for about a minute. The check engine light and VSC lights are all off now, but the vehicle will barely idle (approx 400 rpm). Even to start it I have to give it a little gas or it will die. Any thoughts?
mooockie is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 09:10 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Hopefully it will straighten itself out once it recognizes the new O2 sensor.
Old 08-17-2021, 01:53 PM #3
SurferUK's Avatar
SurferUK SurferUK is online now
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
They say to disconnect the battery for 15 minutes before working on airbags, so it might not have completely discharged and maybe even corrupted the original values.
Sounds stupid but first thing I would try before buying any parts or dismantling is disconnect battery for 15+ minutes, even over-night and then try again.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is online now   Reply With QuoteReply With Quote
Old 08-18-2021, 01:13 PM #4
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Low idle and stalling following a disconnected battery are the classic symptoms of a dirty throttle body. That's the first thing I'd look at. May as well clean the mass air flow sensor while you're there.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 03:12 PM #5
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Put the old sensor in and see if it normalizes. If you bought the sensor off ebay or amazon, its prob defective
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 04:03 PM #6
Justbuckstuff Justbuckstuff is offline
Justbuckstuff is on a distinguished road
Literally just went through this. Replaced spark plugs and then it wouldnt idle. The computer adjusted to the new state and it was like 250-400 RPM in gear.
You can still drive it this way if you need to by using both feet and shifting into neutral when stopping then keeping the accelerator going so you control the idle manually.
Cleaned the MAS and throttle body and now it is idling at 1100 RPM in park. I believe now I need to remove the battery again and reset the idle so it adjusts back to being able to breathe.
Justbuckstuff is offline   Reply With QuoteReply With Quote
changed , die , idle , sensor , vehicle
For those that changed their upstream o2 sensor to increase MPG, did it work? TejasRunner01 3rd gen T4Rs 18 04-02-2019 10:58 AM
Error P0141. Changed o2 sensor. Check Engine back Paramedic 3rd gen T4Rs 4 03-20-2015 10:46 PM
Will Bad O2 Sensor Cause Rough Idle . claydoctor 4th Gen T4Rs 12 05-07-2013 06:19 PM
HELP!!!!Changed knock sensor now wont start l_bird254 Classic T4Rs 3 08-25-2012 02:50 PM
Changed o2 sensor still getting Check Engine NM4Runner 3rd gen T4Rs 1 08-30-2010 01:18 PM
