Old 08-18-2021, 05:10 PM #16
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
Napa here, no problems.
Ida4runner is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 07:21 PM #17
Shiftless Joe's Avatar
Shiftless Joe Shiftless Joe is offline
Shiftless Joe is on a distinguished road
Running Napa with the heavy boots, spitting some grease on the passenger side at 5,000 miles. Probably my fault though, I now think I caused a small tear when I swapped in new hubs just prior to seeing grease. I'll run them for a few years until I get around to rebooting the stock ones.
Would still recommend.
Shiftless Joe is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 09:29 PM #18
Flybynight's Avatar
Flybynight Flybynight is offline
Flybynight is on a distinguished road
Flybynight's Avatar
I forget where I got mine from but they are cardone brand and "replaced" my Toyota stockers that both had torn boots last summer. Took my rig in for a Bilstein 5100 / XREAS delete not even 6 months later and the guy calls me and says I need a new CV axle. I said WHAT!? They were JUST replaced! - The large side clamp popped on the driver side and its all exposed.
That's "cardone" for you. Knowing all aftermarket CV's for these were junk I kept my stock ones and will have them cleaned up and re-booted.
Flybynight is offline   Reply With QuoteReply With Quote
Old 04-23-2022, 01:07 PM #19
Kaplar Kaplar is offline
Kaplar is on a distinguished road
CV boot kit
My 2004 T4R OEM CV boot part is 4438-60030 for older style CV axle assembly from 2002-2004. Is there any good quality aftermarket CV boot kit for this kind of axle please? Thanks.
Kaplar is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 10:25 AM #20
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
I noticed one of my OEM inner joint was starting to get a little sloppy. I put on the A1 Cardones for $60 a pop. I've been beating the sh1t out of them over a year on trail non stop. Still smooth as a cloud. OEMs refurbished and trail backups like homie mentioned earlier. I compared them and they are banded in the same manner as OEM and the boots feel like the same material. They're easy to change anyways so F_ck Toyota prices. I'll buy ten sets for the price of one and keep beating them up for fun. Lifted 3" by the way.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 07:02 PM #21
crimedog crimedog is offline
crimedog is on a distinguished road
I've had a few problems with leaks with the remanufactured. And always use OEM seals. But have had real good luck with their new axles. Been running for a couple of years without issue.
crimedog is offline   Reply With QuoteReply With Quote
Old 04-25-2022, 10:41 AM #22
Jayson44's Avatar
Jayson44 Jayson44 is offline
Jayson44 will become famous soon enough
Jayson44's Avatar
this. I have the Napa HD boot axles and they replace them for free when the boots tear. it's easy to swap out, so just swap in the new one, return the old one, keep it until you need to swap again.
I'm lifted 3" and run 35s, wheel probably once a month or so, and I seem to tear a boot once a year on these.
J.
05 v8 Sport - K&N air filter - Toytec Ultimate front + OME 3" rear - JBA HD UCAs - Spydertrax spacers - 35" Kenati Trail Hogs - Vors v37s
Jayson44 is offline   Reply With QuoteReply With Quote
Old 04-26-2022, 10:15 AM #23
Fried Rice Fried Rice is offline
Real Name: Dillon
Fried Rice is on a distinguished road
Real Name: Dillon
I have about 4 years and 50k miles on the NAPA premium axles with the HD boots and have not had a problem so far. I am not a wheeler but I do have the adjustable Bilstiens with 1” lift on the front just due to the occasional minor flooding I have to deal with in my area.
As I recall I was able to order online with a pretty decent discount and have them delivered to the store. The price ended up being close to the junk that some of the other stores sell as axles…
2008 Urban Runner 4WD
X-REAS Delete / Bilstien 5100 + Rear FJCs
Fried Rice is offline   Reply With QuoteReply With Quote
Old 04-29-2022, 12:47 PM #24
tylrdvs277's Avatar
tylrdvs277 tylrdvs277 is offline
tylrdvs277 is on a distinguished road
tylrdvs277's Avatar
Originally Posted by theoutbackdream View Post
Been doing some digging around since I don't want to spend $500 on an OEM Toyota Axle if I don't need to. Seems like my options are either OEM, CVJ, or Napa
Given the fact that Napa is the cheapest option , I did some digging around across multiple Toyota forums (T4R, TacomaWorld, FJCruiser forums to name a few) and it seems like they're a good alternative. However, most of the posts are 2+ year old with mixed data points, mostly good reviews with a few bad due to possible other variables (using the remans instead of new, longer than factory shocks but not LT, only used as a spare/temporarily)
From my findings, the NCV 944052 should have a standard boot, while the NCV 944082 have a heavy duty boot. But they are also supposed to have a $30 diff (currently $1 diff), and made by CARDONE (currently made by SurTrack PN: TO-8168)
Check Napa link for the SurTrack PN -> Attention Required! | Cloudflare
Amazon review of the TO-8168
Amazon.com: SurTrack TO-8168 CV Axle Shaft : Automotive
Has anyone recently tried Napa CV's?
Interested since I also need new CVs. But the 5th gen CVs are supposed to fit 4th gens even though the part number is different. They are 330 ish. Still expensive but not 500 through Toyota
2008 4Runner V8 4WD Limited (Dobinsons 2.5 inch lift, JBA UCAs, 265/65r18 KO2s)
tylrdvs277 is offline   Reply With QuoteReply With Quote
Old 06-14-2022, 03:27 PM #25
theoutbackdream's Avatar
theoutbackdream theoutbackdream is offline
Real Name: Matt
theoutbackdream has a spectacular aura about theoutbackdream has a spectacular aura about
Real Name: Matt
Sorry for the late reply, but I ended up avoiding the Napa CV's because they changed distributors and the CV's are offered by Surtrack, which I really couldn't find much data points on. With that, I did some digging to find that the "good" CV's from Napa were the ones from Cardone, PN 665235 HD. I haven't done any hard wheeling yet, but they aren't binding at full droop.
Check it out in my build thread. https://www.toyota-4runner.org/3702153-post215.html
2007 Limited V6 4WD Build Thread
Find me on Instagram @t4r_explorer
theoutbackdream is offline   Reply With QuoteReply With Quote
boot , diff , good , made , napa
My recently acquired 3rd Gen!! HDMac07 3rd gen T4Rs 20 05-10-2017 06:15 PM
Recently purchased robbjo1691 Classic T4Rs 3 10-02-2012 04:14 PM
Which axle napa new or napa reman.Maxdrives WHORERUNNER 4th Gen T4Rs 5 07-13-2012 09:24 PM
Anyone buy new TR4 recently? Aurora85 4th Gen T4Rs 25 01-15-2009 06:14 PM
recently had problems w/ my T4R skkiii_whhaattt 3rd gen T4Rs 1 07-17-2006 02:22 PM
