Old 08-17-2021, 09:45 AM #1
jacob7071 jacob7071 is offline
jacob7071 is on a distinguished road
Houston area mechanic - v8 timing belt replacement
Hi all. I'm coming up on 180K miles and would like to avoid the stealership for the timing belt / water pump replacement. Does anyone know of a good mechanic in the Houston area who could do it?
Houston, TX - 2007 2wd Limited Build Thread
Dobinsons 296/220 front and 505/705 rear, Graphite Tundra split spokes, 5th gen Tube Running Boards
Sold '02 Sport Edition
jacob7071 is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 11:11 AM #2
bebop's Avatar
bebop bebop is offline
Real Name: Sean
bebop is on a distinguished road
bebop's Avatar
Real Name: Sean
Can't give you prices as I live in Austin but, most people from the Houston area use Duggy's Garage. I believe he's even on Tacomaworld. Might cost a bit more but, the dealer usually doesn't do more than just the timing belt/water pump. The thermostat was a different bid.
I went to a Land Cruiser specialist place where they changed TB, all tensioners, WP/thermostat, fuel filter, missing something else. They used the AISIN kit you can buy on amazon (you can provide to save money) but, they were about $300 more than the dealer which, again only did the TB/WP
2008 V8 4Runner Limited- Stock
1999 3rd Gen Limited
2020 TRD ORP
bebop is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 09:33 AM #3
I appreciate the reply. The quote did come back a little high. The first one was really high because they quoted the timing belt, water pump and serpentine belt as 3 different jobs, basically triple counting the labor. They did revise it down a bit, but the part quotes still look high. I'll see if they'll let me source them myself to save some $. Thanks for the suggestion.
Old 08-30-2021, 11:01 PM #4
CDNsurf CDNsurf is offline
CDNsurf is on a distinguished road
When I was down in that area I found these guys through a Tundra Forum that had some good reviews. The owner was a Master Toyota Tech.
Tomball's Choice For Auto Repair
It was just over $1000 for the timing belt, water pump and new anti-freeze. At the time I believe the dealers were ~$1200-1400.
Good luck.
CDNsurf is offline   Reply With QuoteReply With Quote
area , belt , houston , mechanic , timing
v8 timing belt replacement - Houston jacob7071 Maintenance/Detailing 0 08-16-2021 04:09 PM
Denver area: Tools for Timing Belt Replacement to loan? denvermaxd 3rd gen T4Rs 1 03-28-2020 11:56 PM
TIMING BELT & PUMP KIT 3rd generation how much time for mechanic required? mickeyt 3rd gen T4Rs 5 10-17-2017 12:41 AM
Mechanic Recommendations for Timing Belt in Denver HustleHard 4th Gen T4Rs 4 09-14-2015 08:54 PM
Mechanic Messed up Timing Belt Change Axtell.Rogue Engines / Suspension / Wheels / Tires / Audio / Accessories 3 04-01-2015 05:39 AM
